2006 22' International CCD
2007 Base Camp
Elk Valley
, British Columbia
Micro-pulse cut wires???
So... I like to take things apart to see how they work... popped off the micro-pulse controller, and there was a flash of spark behind it...
On one switch... I think the water pump switch... there was a 6 inch long piece of green wire that was cut and left bare-end. I took it off in the photo. Anyone know what the third pole of that switch was supposed to go to? The water pump works...
Part two... there is a section of what looks like 4 conductor phone wire just cut off and left with no end (the blue wire in the pic...) I'm just guessing that there was a problem with a tank, or sensor, and someone replaced one of the 'phone cords'. Why would they cut the end though... and why not pull the old wire? I would have used the old wire to pull a new one through...
Any thoughts? I'm more worried about the green switch wire going to nowhere (and I think what created the spark)... I know... power off... but I wasn't expecting bare wires!
Hi, I think I removed the green wire or protected the end on mine. [don't remember] I believe that the green wire is for units that have a water pump switch in the bathroom. [mine doesn't] So the green wire does nothing. As for the phone cords, You should have one for each of your tanks. [fresh, black, and grey] Some trailers have propane sensors, mine doesn't, but mine doesn't have a place to plug in or have propane marked on the monitor cover.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
2007 Base Camp
Elk Valley
, British Columbia
I've got Fresh, Black, and Grey on the panel, and a cord running to each... I haven't used the water yet, but they seem to be reporting two empty waste tanks and 1/8 tank of fresh water.
I put the green wire back on with a Marette, and put one on the phone wire as well...
I wish I had the build manual for it... I had one for my Basecamp and it made troubleshooting a lot easier...
