Old 07-30-2010, 04:38 PM   #1
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Metal waste tanks?
Hi.
I have in the past made custom metal tanks for different uses, like fuel/coolant in antique aircraft, or fresh water tanks, without problems.
Are there any special considerations with gray and black waste tanks that would limit metal choices due to corrosion, wear, fatigue or etc?
I ask, because I could fabricate custom tanks in metal more comfortably and easily than in plastics or fiberglass. I can also do things like make a sealed inner tank, then an outer tank with a 1" insulated space, so tanks don't freeze in winter, and also, the tanks would be perfect fits for my projects.
What do you think? What am I missing?
TX-16
Dave Park is offline   Reply With Quote
Old 08-14-2010, 02:30 PM   #2
Dave Park's Avatar
2005 22' Safari
Anyone? Bueller? Bueller?
I'll even take opinion over certainty!
TX-16
Old 08-14-2010, 03:01 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Wouldn't metal tanks corrode in a few years? Esp. black water with chemicals we use?
Kay
Old 08-14-2010, 03:09 PM   #4
Dave Park's Avatar
2005 22' Safari
I can line metal tanks with plastic coatings, so no metal/black water contact is possible.
TX-16
Old 08-14-2010, 03:43 PM   #5
1972 Travelux Princess 25
Cobourg , Ontario
They used to use tanks made of galvanized sheet metal at least for fresh water, they switched to plastic because they are easier and cheaper to make.
Corrosion and freezing are the 2 big problems. If you have the corrosion problem beat with a lining then all you have to worry about is freezing.
Make the sides taper like a funnel or inverted pyramid. That way if they freeze the water climbs the sides and does not do any damage. Insulation will help but will only stave off freezing for a few hours. You need to assume they will freeze solid at some time.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 08-14-2010, 03:50 PM   #6
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Originally Posted by Dave Park View Post
Hi.
Drain, fill openings would have to conform to industry sizes. Stainless steel would be pretty much corrosion proof for a looong time.
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 08-14-2010, 04:10 PM   #7
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I think Stainless steel would be the ideal choice.
Old 09-05-2010, 06:34 PM   #8
mbrod666's Avatar
1959 24' Tradewind
Roseville , Minnesota
Steel
I personally like epoxy lined mild steel for a number of reasons including ease of fabrication and flexibility. Stainless has issues with being brittle and stress corrosion cracking caused by exposure to acid and some chemicals. That's why most stainless steel transports have interior linings.
mbrod666 is offline   Reply With Quote
Old 09-05-2010, 08:25 PM   #9
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Hi.
The tanks would have to Stainless Steel. Bodily output is corrosive as well as some of the chemicals used to keep the smell down.
The tank would have to be well supported.
Michelle TAC MT-0
Sarah, Snowball
Old 04-26-2012, 07:24 AM   #10
duggie's Avatar
1959 24' Tradewind
Monterey , California
What would you line the interior of the stainless tank with?
duggie is offline   Reply With Quote
Old 04-26-2012, 08:17 AM   #11
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
I don't think you can beat the "plastic tank" for weight savings.
Dave
Old 04-26-2012, 08:47 AM   #12
1981 31' Excella II
New Market , Alabama
Stainless steel would work but you need to know what you are doing with welds. Welds are where you’re going to have the most problems because you don't know what the properties are going to be once something is melted and stuff segregates. I would tend toward plastic holding tanks and if you must then make a stainless steel fresh water tank. Stainless does not like chlorine so you have to be careful on when you sterilize tanks not to overdo it. You want 300 series stainless steel.
Perry
Old 04-26-2012, 08:54 AM   #13
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Just to piggy backon this thread...
Does anyone have an opinion or knowledge to offer on using 5052 aluminum ( its supposed to resist corrosion some) for a FRESH WATER tank?
Sergei
SmokelessJoe is offline   Reply With Quote
Old 04-26-2012, 09:04 AM   #14
1981 31' Excella II
Anodizing would be best but it needs to be done after fabrication. It might be ok without it. Aluminum is used in cooling systems with anticorrosion additives and you don't want that in your drinking water. For long term storage I am worried a little. Typically it is used for things like diesel fuel that is relatively non-corrosive.
Perry
Old 04-26-2012, 09:15 AM   #15
1976 Argosy 24
I should also clarify that the FRESH in my case is never used for driinking, only washing.
Sergei
Old 04-26-2012, 09:54 AM   #16
Kevin245's Avatar
I would not line the interior of a stainless tank.
William C. Swinney
Old 04-26-2012, 10:34 AM   #17
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Dave
Agree heartily. Also there are several suppliers with reasonable prices.
Paula
Old 04-26-2012, 11:45 AM   #18
1976 Argosy 24
Using plastic is only viable if you can use a stock size, tons of which are available.
Dave Park, who originated the question is a skilled builder so he must have in mind a special size.
Metal is the only reasonable way in that case. A plastic blow molded tank would require paying for a mold and if you need to bend sheet goods you need an giant oven so special size plastic will be cost prohibitive.
Sergei
Portable waste tanks millvalleyca Waste Systems, Tanks & Totes 17 06-27-2010 06:52 AM
Waste tanks lahrfarm Waste Systems, Tanks & Totes 5 03-01-2010 02:51 PM
Polyethylene or ABS for waste tanks? SilverHoot Waste Systems, Tanks & Totes 5 07-21-2009 05:18 PM
my '59 has no waste water tanks. What now? r&kweber Waste Systems, Tanks & Totes 9 08-17-2006 03:45 PM
Waste Water Tanks jalewis Our Community 2 07-31-2003 08:01 PM
