Old 02-25-2009, 10:30 AM   #1
blickcd's Avatar
Milford , Ohio
Macerator pump lift restrictions?
I've read a lot here about using macerator pumps for quick dumping or pumping thru a small hose over a long run.
What I want to know is how high can these pumps lift or push the liquid waste? My intended use would be to fill a large tote tank in the back of my pickup using a portable macerator on the ground connected to the trailer's outlet with a short slinky. Would it work?
Christopher
blickcd is offline   Reply With Quote
Old 02-25-2009, 11:59 AM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
"Lifting" (or pulling) on the suction side would be a problem - the literature I've seen seen from Jabsco (even on their low end pumps) says 350 feet of discharge hose or 20' of head....
As long as your discharge is not too small (or too long) the 4' or 5' of llift needed to get into a tank in the P'up should not be any problem.
Note that performance drops off dramatically the more restriction in the hose (head, length, diameter).
IMO, your intended use would be ideal for the Jabsco (or other) macerator systems.
Don't go too small on the discharge side since any restriction will cause the solids to bridge over. I have used 25 feet of 1 1/2" discharge hose on the 345 with good success
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 02-25-2009, 12:40 PM   #3
blickcd's Avatar
Milford , Ohio
Thanks. I was planning on usuing a 1-1/2" discharge hose at a minimum. This is just an idea for some future boondocking. Those pumps are pretty expensive so I would hate to buy one and not have it work. Probably can't return it after the first use.
Christopher
Macerator pump Brad Hunt Waste Systems, Tanks & Totes 10 09-29-2007 10:45 PM
Firewood Restrictions in your state? CanoeStream On The Road... 15 07-30-2006 08:09 AM
Valve before or after macerator pump? malconium Waste Systems, Tanks & Totes 7 07-29-2004 04:20 PM
Macerator pump uncleneal Waste Systems, Tanks & Totes 4 03-12-2004 09:40 AM
Campground restrictions Ira Iburg Our Community 7 08-03-2003 04:12 PM
