Old 09-25-2007, 08:37 PM   #1
2007 25' Safari SS SE
Alton , Illinois
Macerator pump
I have read about macerator pumps in articles about motorhomes--Is one of these pumps possible or better yet practical in an AS TT? Seems like Teche is a good brand--any thoughts or comments? Thanks, Brad
The "Ann Rutledge"
Brad Hunt is offline   Reply With Quote
Old 09-25-2007, 09:17 PM   #2
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Brad,
I will likely add a macerator to my waste system during my redo. I have not decided what brand to buy but here are a few pump/systems that I have bookmarked.
FloJetŪ Macerator Pump
Jabsco Macerator Pump
CLEAN DUMP RV MACERATOR SYSTEM
And here is a link to some info from Phred Tinseth:
MACERATORS AND OTHER SEWAGE STUFF
Please let me (us) know what you discover!
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 09-25-2007, 09:35 PM   #3
Images: 59
I added a macerator pump on my '59 Tradewind. There are a couple of pictures in my photo gallery.
A couple of things to keep in mind:
1. Make sure you have an alternate way to dump if the pump breaks or the battery is dead.
2. Good idea to have a warm air duct to keep the pump warm during freezing weather. I installed a muffin fan and duct from the bathroom after the photos were taken.
3. I wired mine through a relay, then use a switch on a lanyard to operate the pump. I can stick the 3/4" hose in the "hole" with one hand and turn the pump on with the other. Quick, clean, and easy.
4. Consider adding a tank flusher while you are putting in the pump.
I think it's a great idea!
Regardless, some will say it's overkill.
Old 09-29-2007, 03:09 PM   #4
Tinsel Loaf's Avatar
When it comes to Turd Wrestling nothing beats a macerator in the ring or outside of one. We always carry one when it’s time to blow the ballast in a hurry. Carry a one-inch hose from 50 feet or longer so you can reach a clean out at the outside of your house or some place else. Always a great tool to have when nothing else will rip and shred the real stuff people are made of.
Tinsel Loaf is offline   Reply With Quote
Old 09-29-2007, 05:53 PM   #5
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Not to hijack
But do you guys really have that big of a problem getting the waste to flow out of the tank? What am I missing?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 09-29-2007, 06:15 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Gen Disarray
...? What am I missing?
I use a portable macerator pump at my house since the Overlander is too far away from a 3-inch line to dump directly.
With our style of camping, there is no need to incorporate a macerator into the Airstream or carry it with us.
Tom
Old 09-29-2007, 07:05 PM   #7
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Macerator pump the simple way.
Macerator pump the simple way. I glued a Macerator pump to a clear elbow using marine epoxy. When I want to use the pump I just connect it to the outlet instead of the dump hose. You will want to add a 12 volt cord to go to battery or run a connection to the dump area, please fuse appropriately. I use the pump to dump my tank to my home sewer system to a cleanout approximately 50 feet away. The clear clean out has a hose connection so you can rinse the tank. I carry it in the bumper of the trailer, I have never used it on the road. If you do a search on RV net several different designs are floating around for portable Macerator pump, some are even built into cases.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 09-29-2007, 07:10 PM   #8
1967 28' Ambassador
1970 29' Ambassador
Gen D,
I don't know if I have a problem getting the waste to flow since I've never "flowed" my waste... but while I'm at renovating my trailer I'd rather set things up to operate via the push of a button than to have to play around with a 3"x 8' long sh*t filled slinky.
Steve & the crew
Old 09-29-2007, 07:44 PM   #9
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Originally Posted by wader
Gen D,
..... I'd rather set things up to operate via the push of a button than to have to play around with a 3"x 8' long sh*t filled slinky.
So is the idea to be able to get rid of the sewer hose for a garden hose?
Rodney
and the
My Blog
Old 09-29-2007, 08:31 PM   #10
Images: 59
Yeah. I'd rather wrestle a garden hose than a slinky.
That was 100% of the motivation in my case. Well, 90% anyway. The other 10% was because the blacktank outlet was on the curb side rear, and my graywater tank outlet is streetside center. I routed the macerator line up to streetside center so both outlets are at the same place. Much more convenient.
The outlets are Teed together so I use the same hose for both, and the graywater pushes out the residual black stuff.
Finally, I like having the threaded connections on the garden hose, and not having to worry about a slinky hose slipping off it pins, or coming undone when the flow is greatest.
Old 09-29-2007, 10:45 PM   #11
Wayward's Avatar
Cary , North Carolina
Brad, you might take a look at the Sewer Solution. If you have a water supply (e.g. campground, home, or dump station), the Sewer Solution is a fairly effective macerator and can pump a pretty good distance.
One big advantage is that it cleans itself up nicely and is easy to stow.
Sewer Solution
............Scott
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Macerator and Holding Tank Sensors SmokelessJoe Waste Systems, Tanks & Totes 1 01-04-2006 08:47 PM
Portable Macerator Use TomW Waste Systems, Tanks & Totes 5 05-03-2005 07:51 PM
Valve before or after macerator pump? malconium Waste Systems, Tanks & Totes 7 07-29-2004 04:20 PM
Macerator....do I need it? Rog0525 Waste Systems, Tanks & Totes 5 04-04-2004 08:39 PM
Macerator pump uncleneal Waste Systems, Tanks & Totes 4 03-12-2004 09:40 AM
