Old 10-17-2007, 12:11 PM   #1
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Macerator connection
I've been searching the internet for any and all options to purchase a macerator for my waste system redo. I can buy a "plain" macerator for $150 +/- ... I can get macerator "kits" with various necessary and unnecessary parts for between $240 and $600. All of the necessary parts required, I have found available to be purchased separately except the piece that connects the macerator inlet to the 3" Valterra valve outlet. When I do the math it seems that I am paying way too much for this connector fitting included in the kits.
Anybody know where I could purchase such a fitting? ...any other ideas?
See attached pictures for reference. (the flojet plain.bmp is the macerator without any fittings)
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 10-17-2007, 01:10 PM   #2
Images: 59
If you go to Lowes, you can find a rubber adapter in the plumbing section that is a nice fit over the end of the macerator, and it also fits nicely over a standard 3" abs fitting. You can see a picture in my photo album. Going from the 3" ABS to a 3" Valterra is just a matter of glueing on the right (hub or spigot) type valve coupling.
In the photos, I reduce back down from 3" to 2" ABS because that is the size of my blackwater tank outlet.
markdoane is online now   Reply With Quote
Old 10-17-2007, 01:33 PM   #3
1967 28' Ambassador
1970 29' Ambassador
Thumbs up
Great photos!
So I could use something like this combo . Thanks!
Steve & the crew
Old 10-17-2007, 04:31 PM   #4
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Clear fitting and some epoxy.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 10-17-2007, 05:34 PM   #5
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
is this the same concept of the sewer solution?
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 10-18-2007, 04:22 AM   #6
1967 28' Ambassador
1970 29' Ambassador
I think "the sewer solution" just uses a high velocity water jet to "suck" the waste out. A macerator is pretty much just like the garbage disposal in your kitchen sink. It can grind up and pump the waste through a garden hose for a l-o-n-g distance.
Take a look at the cleandump site. They have some good info explaining what a macerator system can do.
...and also look at Macerators and Other Sewage Stuff by phred
Steve & the crew
Old 10-18-2007, 08:06 AM   #7
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Smile
Steve
Save yourself the hassle of gluing the parts together and buy the kit from Flojet. I recently bought the Flojet Model 18555-000 Portable RV Waste Pump Self-Priming Macerator on E-Bay for $170.00 plus $16.95 shipping. The kit came with the macerator, a remote handheld switch and 6í wire, a hose connection to back flush the system, a hose connection to run the waste to a sewer connection, and a case to store everything. Itís compact and has no leaks.
2dabeach is offline   Reply With Quote
Old 10-18-2007, 09:25 AM   #8
1967 28' Ambassador
1970 29' Ambassador
Originally Posted by 2dabeach
Steve
Sounds like you got a good price... I have not seen them that cheap. More like $220 with shipping. Even at your price, it seems like I end up paying $40 for an $8 part.
Thanks for the input... I'm still weighing my options.
Steve & the crew
Old 10-18-2007, 10:17 AM   #9
urbanfood's Avatar
Venice , California
steve, great link. i'm going to look into trying to do it similar to what they show in the diagram. my gray and black tank configuration will be almost exactly what they're showing. keep up posted on your decision, i'm curious to know which way you go.
david
Macerator pump Brad Hunt Waste Systems, Tanks & Totes 10 09-29-2007 10:45 PM
Portable Macerator Use TomW Waste Systems, Tanks & Totes 5 05-03-2005 07:51 PM
Valve before or after macerator pump? malconium Waste Systems, Tanks & Totes 7 07-29-2004 04:20 PM
Macerator....do I need it? Rog0525 Waste Systems, Tanks & Totes 5 04-04-2004 08:39 PM
Macerator pump uncleneal Waste Systems, Tanks & Totes 4 03-12-2004 09:40 AM
