Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 11-28-2004, 11:40 PM   #1
Hit'the'road's Avatar
Profile:  2005 25' International CCD
Pope Valley , California
Macerating black water pump
I got a macerating pump to use when emptying the black water tank. It operates on 12V and needs to have a plug wired in to connect to when pumping. Does anyone have a good idea how to wire this in on a 2005 25' International?
'05 Chevy Silverado 6.OL Quadrasteer
'05 25' International CCD
Hit'the'road is offline   Reply With Quote
Old 11-29-2004, 06:01 AM   #2
uncleneal's Avatar
Profile:
I permantly mounted mine in my '89 Squarestream. I put a push-pull switch in the compartment above it and ran a wire back to the fuse box. It's wired into a (previously) unused fuse space with its own fuse.
Neal
uncleneal is offline   Reply With Quote
Old 11-29-2004, 07:05 AM   #3
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 234
Macerator Installation
Originally Posted by Hit'the'road
I got a macerating pump to use when emptying the black water tank. ...... Does anyone have a good idea how to wire this in?.....
This is what I did on the 345 - I mounted a "Blue Seas Systems" switch (West Marine) in the utilities bay. Installed a fuse in the 12 volt service box.
I had previously ran a 4 gauge breaker protected wire from the house batteries to the rear of the unit. - Make sure you do a voltage drop analysis on the guage of wire and the length of the wire run for the amperage your pump will pull.
When dumping - Pump out (dump) the black tank first, then equalize the gray water into the black tank, close the gray water tank valve, pump out the black tank again. Equalize the grey and black tanks again, close the grey valve again, and pump out the black tank. Equalize the grey and black tanks one more time, close off the black tank, pump out entirely the grey tank.
By leaving a few gallons of water in the black tank you have a better chance of keeping all of the residual solids in solution, and prevent a build of of dry solids on the walls of the black tank.
Also, by keeping the "water charge" in the black tank you minimize the possibility of the dreaded "brown solids mountain" accumulating in the black tank - the "Brown Mountain" is no fun to deal with - guess how I know.
From now on, I always keep a few gallons of water in the black tank.
ID:	9601   Click image for larger version
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 06:31 AM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Flushing Black Water Tank 1985air345 General Motorhome Topics 3 05-16-2002 02:59 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
