Old 11-23-2014, 03:54 PM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Looking to replace black/grey tank vents
I have a 2001 Excella and am looking at the waste tank vents on the roof. They both are of the plastic type. One looks to have a cracked base flange and both need re-sealing if I keep them. I would like to replace both of them with a metal one if they are available. The factory website shows a plastic replacement with a built in bug screen barrier. I checked VTS and ODM and don't see what I'm looking for. Is there a source for a replacement vent in metal ????? Appreciate any help in sourcing these vents. In a pinch I can make do with the ones I have but if I need to go to the trouble to clean them up and re-seal I might as well replace with something better if I can find them.
Thanks all, See ya on the road sometime.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-23-2014, 04:32 PM   #2
You can use the older type polished metal sewer vent pipe covers that Airstream used for about 40 years.
You will also need the separate gasket.
Old 11-23-2014, 08:16 PM   #3
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Hi there, check this thread out. http://www.airforums.com/forums/f478...ml#post1257454 - Brad
SuperTrouper is offline   Reply With Quote
Old 11-23-2014, 08:48 PM   #4
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Post 1 shows an aluminum vent cover. Post 7 is where to get them.
http://www.airforums.com/forums/f455/waste-vent-cap-60573.html
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
VTS Vintage Grey Tank for Black Tank? bluemoontwo Waste Systems, Tanks & Totes 1 11-27-2012 08:03 AM
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 06:47 PM
Sealing black and grey tank vents The Driver Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 10-03-2011 10:05 AM
