Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 11-07-2009, 10:33 AM   #1
MyFirstStreamer
Zstream's Avatar
Profile:  1963 26' Overlander
Indiana , Indiana
Looking for Valterra dual dump valve
Does anyone know the part number for this dual valve?
Before you buy from an AS parts supplier, I recommend you verify the veracity of any claim of Incorporation w/ the respective Depart of Sec.of State, Also, check w/ local courts & verify the existence &/or lack of lawsuits pending against the supplier BEFORE you make a purchase. Stay safe!
Zstream is offline   Reply With Quote
Old 11-08-2009, 10:26 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Hi Z. The black tank is toward the top; flow is downward when you dump? The side inlet is the gray water?
The part you're showing is from a vendor? Your Airstream?
I'm trying to understand who might have a connection through their experiences and would be your audience for this question. Let's try to get you hooked up.
Old 11-08-2009, 11:38 PM   #3
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
I can probably find something tomorrow, and either post about it, or PM.
(No Longer at Inland RV)
Old 11-09-2009, 12:20 AM   #4
Profile:  1965 17' Caravel
Southern , Connecticut
Looks close to a 89-8471.
Does this help? RV Plumbing - Valterra Valve Body
65CV is online now   Reply With Quote
Old 11-16-2009, 11:27 PM   #5
Well-Preserved
I found one buried on a shelf at work. It is a Valterra T-1011.
Valterra Valve question 65CV Waste Systems, Tanks & Totes 0 07-14-2009 10:14 PM
Replace a Thetford Valve with a Valterra? thunder433 Waste Systems, Tanks & Totes 2 03-03-2008 05:41 PM
dump valve (once again) eubank Waste Systems, Tanks & Totes 13 09-08-2007 11:56 AM
Dump Valve Sneakinup Waste Systems, Tanks & Totes 27 05-23-2005 03:31 PM
Dump valve ALANSD Waste Systems, Tanks & Totes 4 12-04-2002 07:07 PM
