Old 07-17-2009, 08:09 AM   #1
1963 22' Safari
warwick , Rhode Island
looking for an underfloor blackwater, 63 safari
hey all,
i'm new here. i just bought a 63 safari, 21 foot, from a friend. it needs alot of help. the rear plumbing was destroyed by a battery that broke loose. i'm trying to find a replacement tank and i'm not having any luck. the tank was mounted under the floor in the rear. can anyone send me in the right direction?
thanks all... man, do i have alot of questions...
Jay
jasoncase is offline   Reply With Quote
Old 07-17-2009, 08:41 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I believe Inca Plastics supplied a lot of the original black tanks to Airstream...you may want to check with them.
Shari
Old 07-17-2009, 08:48 AM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Also check with Andy at Inland RV Inland RV Center - The Nations Leading Expert in Airstream Innovations I got my new one for my 68' from them.. Nice fiberglass one that should out last me...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-17-2009, 09:30 AM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I got mine at Inland RV also. Really nice tough fiberglass tank. It had better out last me!
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 07-17-2009, 09:56 AM   #5
1963 22' Safari
thanks guys,
i've got an email in to andy, hope to hear back soon, otherwise i'll call them up... you guys, mind giving me an idea of the pricing?
also, another question, it looks like the last guy, cut the lines from the water tank and made the system fresh water input the rear hose fitting, i want to reconnect the tank but, i'm a tad baffled by what i'm seeing at the front tank. is there any type of diagram of how one of these systems are supposed to work?
thanks again
Old 07-17-2009, 09:58 AM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Jay!
Your tank looks virtually identlical to the one in my '64 Overlander. I, too, purchased my replacement from Inland RV earlier this season as well as the Thetford Collector and Gate Valve. The tank is not pre-drilled for the toilet -- the necessary parts were included to place the fittings where required for the particular coach in which it was to be installed. A local Brand X dealer handled the install for me and commented that the parts were of very high quality and the install was very smooth.
Good luck in your search for a new tank!
Kevin
Kevin D. Allen
AIR #827
Old 07-17-2009, 10:02 AM   #7
1963 22' Safari
thanks... glad to hear that it looks familiar to someone... we'll see what andy says.
Old 07-17-2009, 11:19 AM   #8
VIKING's Avatar
Boulder Creek , California
These are shown on Inland rv's website. I think they are $455.00 plus shipping. I'd hate to see what it takes to ship it to Rhode Island! Maybe your tank can be repaired? It really does'nt look very bad. The cracks in the top can definitely be glassed over, and if the bottom is no worse, you might save yourself some franklins.
Don't tell Andy I said that!
Rich
VIKING is offline   Reply With Quote
Old 07-17-2009, 02:21 PM   #9
FreshAir's Avatar
1966 24' Tradewind
Rich
That's what my b-tank cost 3 years ago. Nice to hear that that price has remained stable. At the time Andy seemed to have the only one for my coach available. Might be other resources available. I was very satisfied with the toughness of Andy's fiberglass tank.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 07-17-2009, 04:11 PM   #10
purman's Avatar
1968 28' Ambassador
The old plastic is not advised to repair, I did a small crack on mine that held for a year, but your are talking about 40 + years old. In the long run, If you can afford it, get the new one... Mine old tank was sagged on the top and the PO shoved wood around it $&%@.. bad PO bad PO....
I used the flange around the top of the new tank to screw it to the floor. I didn't like the old method of keeping it in.. This way it can't come off. I drilled holes every 6" Big fat screws all around then put the original stuff back in after it was up..
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-17-2009, 06:00 PM   #11
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
Well you are halfway there to where we decided to go. Take out the black tank and install a composting toilet! No black tank, no dump stations, no chemicals, no smell! By the time you add up the cost of the tank and the toilet etc. you will be close to what we spent. If you or anyone else would like more info...let me know!
FLYNCLD
FLYNCLD is offline   Reply With Quote
Old 07-17-2009, 07:33 PM   #12
1963 22' Safari
so, does your grey just dump straight out? i'm trying to figure something more affordable then the stock replacement out?
Old 07-17-2009, 07:36 PM   #13
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Interesting your 63 safari had an in floor tank, ours was above the floor, did someone modify yours previously or was yours a really late 63 that had the bathroom setup of a 64 or something?
I'll try to dig up a few threads that had tank mods going, a few that even put gray tanks in vintage rigs.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 07-17-2009, 07:38 PM   #14
1963 22' Safari
yeah,
i'm not sure what the real story is, it looks half stock and half hack job, i'll have to post some interior pics of the bathroom. i'd love some one to be able to clear it up for me.
Jay
64 GT Blackwater tank 64TrotterAtl Waste Systems, Tanks & Totes 4 09-27-2008 11:48 PM
How big is blackwater tank for 1999 Safari 25' Aluminumb Waste Systems, Tanks & Totes 2 12-17-2007 05:00 PM
Size of Blackwater Holding Tank 1999 Safari 25' Aluminumb 1999 Safari 0 12-17-2007 11:04 AM
Underfloor Water Tank muddy_hollow LP Gas, Piping, Tanks & Regulators 8 01-25-2007 02:00 PM
'52 blackwater tank Cruiser Waste Systems, Tanks & Totes 1 09-01-2003 08:28 PM
