Old 11-12-2009, 10:46 AM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
location of tanks 74 overlander
Are the waste tanks side by side in the rear on this model?
I understand the 74 has g&b tanks?
Where is the fresh tank located?
bwaysteve is offline   Reply With Quote
Old 11-12-2009, 10:52 AM   #2
Rear bath, center bath?
The water tank is forward of the axles.
Old 11-12-2009, 08:36 PM   #3
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
location of bath
This is a rear bath model
Old 11-12-2009, 10:15 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Black tank is under the toilet, and the grey tank is under the tub. Black should be about 25 gallons, grey about 10-15 gallons, and fresh is about 40 gallons.
Old 11-13-2009, 10:48 AM   #5
The black tank is on the left side and the gray tank is on the right side.
They are about the same capacity.
Old 11-13-2009, 11:05 AM   #6
If you need one of those tanks, be advised that they are no longer available from Airstream.
However, after market tanks are avaliable, some made with fiberglass, some with plastic.
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
Black/Grey water tanks 1968 Overlander StuartM Waste Systems, Tanks & Totes 4 03-22-2007 06:43 PM
65 Overlander Propane tanks PhilMateo LP Gas, Piping, Tanks & Regulators 7 12-25-2005 08:23 PM
Tanks size and location wahoonc 1980 Excella II 2 06-12-2005 05:39 PM
