Old 01-15-2004, 01:18 PM   #15
Confused & Wandering
Theo's Avatar
1993 34' Excella
Right here, , where ever I wake up
Send a message via AIM to Theo
The search works..
So, I have no grey tank on my '72 safari 23'.. I just about figured as much..
The grey water collects all by itself in the outlet pipe...
A light goes on in my mind, expaining the clean water that came out of the little cap in the drain cover.. SO... I need to use the never used, but carried faithfully blue tank, all 30 gallons of it, that I have had for 4 years.
I think that adding a grey tank is way above my capabilities, so I have to adapt to the blue problem... In a full hook-up site there is no problem because it all goes down the same hole, from the same hole.
The black tank is above the floor, in the box under the stool... I see. Not much room in there at all, and the shower is indeed lower than the tank, so that is why it got really yuky. Isn't this an adventure.
Thank you guys, you have cheered me up considerably - now at least I know what is going on in there.
Theo
'05 Cargo hauler gooseneck, carrying an '05 Jeep TJ, all hauled by an '05 C4500 Kodiak Truck
Theo is offline   Reply With Quote
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
Gray water tank removal AccessMaster Airstream Motorhome Forums 1 03-07-2004 10:05 AM
Gray water tank Joe62984 Waste Systems, Tanks & Totes 12 01-02-2004 07:45 PM
size of gray water tank mtccollins Waste Systems, Tanks & Totes 3 08-09-2003 05:34 AM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
