Old 09-21-2010, 06:29 AM   #1
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Light stays on
On my control panel the 4/4 light on the waste tank stays on. It stays on even if I unplug all of the sensors from the tank. Anyone know where I should start troubleshooting this one. It has been like this since I got the trailer 2 years ago. I am in the process of replacing the bathroom floor and thought, this is the time to fix this problem but I cannot find anything wrong yet. This evening I am going to do a continunity check to make sure there are no shorts or opens in the wires from the tank to the control panel. The only other thing I can think of is, there is something wrong with the circuit board. What are the forum members thoughts on this problem?
Mel
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 09-21-2010, 07:32 AM   #2
x
XXXX , XXXX
I found that my sensor wires were corroded and the insulation had worn away. They were touching each other. This was right where the wires come up through the floor from the tank to join into the harness inside the shell. I had the same reading problem.
wasagachris is offline   Reply With Quote
Old 09-21-2010, 11:19 AM   #3
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
My wires are fine in that area. With everything removed from the floor it is easy to see them. I an thinking of getting a mirror and flashliight and see if I can see the sensors from the commode opening. I can still easily remove the tank if need be. I do not think it is with the sensors though since it will light even if they are unplugged. That kind of points to something else.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 09-22-2010, 10:58 AM   #4
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
It looks like there is something wrong with the circuit board. Will troubleshoot some more tonight. The 1/2 light works fine though.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 09-22-2010, 11:38 AM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
We had the same problem with one of our indicators. I've not had the inclination to tackle it yet so I just ended up pulling the bulb loose to shut it off.
Old 09-22-2010, 11:42 AM   #6
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Maybe there's some old, ummm, "debris" stuck to the top of the tank?
Well, no, it stays on even if you unplug the sensors, though... I just thought the idea of a klingon was funny.
Poop humor - who knew!
TX-16
Dave Park is offline   Reply With Quote
I bet this section stays busy... AIR-Quarius Waste Systems, Tanks & Totes 6 06-29-2010 07:15 PM
Atwood Heater - Red light stays on! Moonstruck Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-06-2009 03:29 PM
'76 Soveriegn Stays in the Family drdehaven Member Introductions 4 08-29-2009 12:24 PM
circuit breaker for 12v stays off airhaus Batteries, Univolts, Converters & Inverters 6 06-06-2009 10:38 AM
Stays lit-water heater pilot light doorgunner Water Heaters, Filters & Pumps 4 07-01-2008 06:15 PM
