Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 07-26-2005, 10:39 PM   #1
jaiman
jaiman's Avatar
Profile:
Images: 32
Leaky BW tank
I wrote this ealier and now cant find it so I will try again. I have a leak near where the the Thetford valve attaches to the tank. The white flange appears to be the culprit. I can turn the flange. It is tight but I can turn it none the less. My thought is that I can pack in behind the flange that enters the tank with plumbers putty or something such as that. I would then use a pipe clamp on the outside just for good measure. Is this a good fix or has anyone else had this issue and found a better or tried and true repair. I dont know if plumbers putty will resist breaking down in such a "shitty" environment. Any help will be greatly appreciated.
Jai
jaiman is offline   Reply With Quote
Old 07-26-2005, 11:19 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
The valve is held to the tank flange by 4 stainless steel screws. If you remove the 4 screws the valve will separate form the tank. Between the valve and the mounting flange there is an O ring. This O ring is one of the set that comes in a standard rebuild kit form Thetford. The kit runs 20 bucks. There will be the seals to replace the internal seal in the valve itself as well as a gasket.
The plumbers putty may work, but the long term fix is to get a new seal kit. the flange should be glued to the tank outlet. If this is where it is leaking you have a bigger problem to worry about. Namely the issue of IF the tank itself is cracked or just needs some more glue
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 07-27-2005, 12:04 AM   #3
jaiman
jaiman's Avatar
Profile:
Images: 32
I have new rebuild kits. I will replace them while I am at it. The leak as I tried to state is from the where the flange and tank come together. I am able to rotate the flange so it is in fact loose. Thats why I was going to put the plumbers putty or other sealant behind the flange to reseal it.
Old 07-29-2005, 11:36 AM   #4
stinkytwinky
1974 28' Argosy TT
stinkytwinky's Avatar
Profile:  1975 28' Argosy 28
Hinsdale , New Hampshire
Thumbs down NOOOOOOO! Stop now Read below.
You either have a glue in or a Clamp in flange, If there is no clamp you probaby have a glue in, Re-glue it. Otherwise replace the clamp.
Still rebuild the valves, they are already off to do the repair.
1974 28' Argosy (Hey, Airstreams are just Argosy's that haven't been painted yet .. )
1999 Ford F250 Lariat SD Extended Cab with 7.3L Power Stroke Diesel
stinkytwinky is offline   Reply With Quote
Old 07-29-2005, 10:20 PM   #5
jaiman
jaiman's Avatar
Profile:
Images: 32
Now thats interesting because the grey water flange/tank has a clamp. Perhaps the clamp has just been removed or fell off for that matter. I saw the clamp on the GW tank and assumed it was added by PO. I would rather fix it properly. Is there a way to tell if I have glue or clamp. Do you know of any pics posted anywhere that could show me the diff. My digital camera is vacationing with my daughter this week so I cant take a pic myself.
Old 07-30-2005, 06:13 AM   #6
thenewkid64
Just a member
Images: 21
If it is a glue in, there would be a glue ridge where the two pipes used to overlap. It could have been a clamp in OEM. I would try a clamp first and see if the leak is fixed. If is I would move on to the next project and jump with joy for a cheap and easy fix.
Brett G
Old 07-30-2005, 07:04 AM   #7
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
jaiman
if it is a clamp on set up, try good old vulkem on the interface between the tank and valve. then add a good quality aircraft hose clamp. i would doubt plumbers putty would work well in the enviroment you describe above!
i had to redo my grey water valve using this method, it has never leaked a drop since i repaired it. AND given the non hardening qualities of vulkem i'm sure i can get it apart again in the future.
this is how my '92 was assembled from the factory. i'll dig up a link with photos if you need it.
you call them ferrets, i call them weasels.
john hd is online now   Reply With Quote
Adding a gray water tank??!! kangol Waste Systems, Tanks & Totes 2 04-21-2004 06:11 PM
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes 0 04-19-2004 08:10 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
