Old 10-11-2006, 07:18 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Arrow Leaking Vent-Tank re-fit
I inherited a sewer vent leak (for several years) from PO, water collected on top of black water tank, I cut the floor out to get to it and change out the gate valves seals which were leaking.
It was a joke trying to get to the valves thru the inspection doors below.
After I opened up the floor I found water puddled on top of the tank in soaking wet insulation.
Now it was almost 5 weeks since I fixed the leak but the water was still there, never dried out.
I redid both valves, cleaned both sets of wires connections going to black and grey tanks, then re-routed them a better way.
Next I formed the foil insulation Promax R-14, it was great to work with, a pair of scissors, some duct tape and it can't get soaking wet ever again.
Last cleaned and painted with POR.
Closed up floor and fibreglassed over, see this thread.
'77 Sovereign Intl 31' CB
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
Is my commode leaking? Fooltime Sinks, Showers & Toilets 5 04-16-2002 09:24 AM
