Old 04-22-2006, 01:46 PM   #29
acton
All holding tanks should be surrounded with fiberglass or styrene.
Additionally, all holding tanks should have heat from the furnace directed direct to the pan. That eliminates the possibility of freeze ups, down to about zero degrees.
The original metal dump valve must be cut off the fiberglass tank.
Then a Thetford "glass on adapter" is fiberglassed to the tank. When that is cured out, you then simply attach a Thetford dump valve to the adapter.
Which valve you use is a function of how creative you may choose to be with the rest of the plumbing piping design.
I have attached a photo of the adapter with one of the valves that can be used.
Ive been trying to locate a "glass on adaptor" but am having no luck. Anyone know where I get this???
Mitch
durans54 is offline   Reply With Quote
Old 04-22-2006, 10:24 PM   #30
1960 24' Tradewind
santa barbara , California
Have you called inland rv ,ask for andy
Scott
scottanlily is offline   Reply With Quote
Old 04-22-2006, 10:34 PM   #31
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Mitch
Dyers RV. They actually call it a "Bond On Adapter". Same thing. Click around, they have all of what you need. Thetford is in the air, that's the third link to them I've posted today!
John
John's Camping Blog
AYRSTRM2 is offline   Reply With Quote
Old 04-22-2006, 10:34 PM   #32
acton
I will try them on monday.
Old 11-10-2007, 11:13 AM   #33
sdiddy's Avatar
1963 22' Safari
Sandia Park , New Mexico
Followup to leaking valve
Hi All,
I have my black water tank out and am wondering if the Thetford Thread-On Adapter at Dyer's is the same as what Andy showed in his pics. It looks similar but I'd prefer to know before purchasing. Also, can one attach an extention to the dump valve for access behind the trailer? Mine is a 63 Safari.
Steve
sdiddy is offline   Reply With Quote
Old 11-10-2007, 12:00 PM   #34
2016 30' Classic
2009 25' FB Flying Cloud
Dade City , Florida
I had the same problem with our 1969 Globetrotter and was able to find a rebuild kit from Vintage Trailer Supply Vintage Trailer Supply - Vintage travel trailer parts and supplies!. I am not positive but believe he only had one or two in stock. The kit worked great and I have had no leaks since.
dbaur is offline   Reply With Quote
Old 11-24-2007, 05:28 AM   #35
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Cool Dump Valves
Has anyony replaced leaking dump valves on a 1985 Sov.?
If so please let me know wghat it will take. If you have any pictures pease sent them to me directly. My emai address is rdworian@comcast.net
Thank you so much Russeell in sunny Tucson Az.:innoce nt:
RUSSELL is offline   Reply With Quote
Dump Valve Sneakinup Waste Systems, Tanks & Totes 27 05-23-2005 02:31 PM
Repacing blackwater dump valve Rick Alston Waste Systems, Tanks & Totes 3 02-03-2004 03:20 PM
water drain valve leaking - help! wayner1239 Fresh Water Systems 14 02-01-2004 04:10 PM
water drain valve leaking - help! wayner1239 Waste Systems, Tanks & Totes 0 01-31-2004 10:03 AM
63 Safari Dump Valve Questions srgntpepper Waste Systems, Tanks & Totes 1 09-10-2003 06:40 PM
