Old 01-21-2012, 04:49 PM   #1
Kansas City , Missouri
Leaking Black Water Tank
We are looking at a 2004 22 ft international ccd. There is rust around the left side seam (facing the back of the trailer) and a little on the back from that edge of the black water tank. The current owner said it leaked a little bit the last time they used it. I am new to Airstream. Is this a big deal and would it be expensive to get fixed?
Thank you
LWPittman is offline   Reply With Quote
Old 01-21-2012, 06:29 PM   #2
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Inspect that trailer carefully. The floor is made of OSB. Many samples of that model have had rotten floors in back. It sounds like this trailer might be a candidate for that.
Also note that there was a reinforcement kit update from Airstream for the frame outriggers on these trailers.
A search of the forums will turn up more about this model. It's a neat floor plan, but make sure the trailer is solid.
Tom
Now: 2007 Safari SE 23' "Anne" towed by 2011 Dodge Durango "Herman"
Before: Argosy Minuet and T@B, towed by various Honda Odysseys
mutcth is offline   Reply With Quote
Old 01-21-2012, 06:38 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Thank you
Find out what leaked and why? Was it the dump valve or the tank itself? Was it an overfilled tank? A leaking dump valve would not be a big deal. A cracked black water tank would.You could fill the black water tank with water and see what happens.
Black water tank valve flange Safari64 Waste Systems, Tanks & Totes 1 09-22-2011 07:50 AM
Black and Gray water holding tank leak GoodRed Road 1974 - 1979 Ambassador 0 09-19-2011 04:39 PM
New '67 Safari black water tank? losfew Waste Systems, Tanks & Totes 1 09-06-2011 06:19 PM
2003 safari - how do you remove black water tank? greenrvlife Waste Systems, Tanks & Totes 3 04-08-2011 10:15 PM
replacing black water tank in 68 Tradewind clydecrashcu Waste Systems, Tanks & Totes 1 01-17-2011 09:28 PM
