Old 06-21-2016, 12:14 PM   #1
1971 31' Sovereign
palm bch. gardens , Florida
Leaking Black Water Gate Valve
My black water gate value is leaking inside of the black plastic tank cover under the camper. There is a hole in the middle of the bottom of the tank that liquid is dripping out of. Luckily I was told that it is the not the holding tank itself leaking but the gate valve. I had it replaced 3 months ago and the technician had an incredible hard time lowering and replacing the cover to change the valve. I am not sure why it is leaking again because it is impossible to see inside. I have thought of cutting a section of the plastic cover out around the gate value for easier access. This is a 2005 25ft safari. Any suggestions?
Peggy Raffer is offline   Reply With Quote
Old 06-21-2016, 02:02 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Cutting a section of the plastic pan for access is a common approach for some repairs. You just have to be careful not to nick the tank or pipes in the process. My 2002 25 had that done to it, and a piece of aluminum screwed in over the hole as a cover.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Slide Gate Valve sizes for gray vs. black richw46 Waste Systems, Tanks & Totes 6 06-12-2016 09:28 AM
'61 Ambassador black tank gate valve leaking Studioman Waste Systems, Tanks & Totes 3 09-28-2014 08:05 PM
Black tank gate valve doesn't close all the way motozen Waste Systems, Tanks & Totes 14 09-08-2014 01:38 AM
New Waste Gate Valve for Black Tank? TylerFyre Waste Systems, Tanks & Totes 5 06-10-2008 01:18 PM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 11:02 AM
