Old 11-15-2013, 11:57 PM   #1
U3270's Avatar
1975 Argosy 24
Fullerton , Cali
Leak from hose near City water hookup
Hello Fellow Campers,
I am in need of help & advice. I took my family on a two night camping trip in our 1974 Argosy. I had a couple issues one of which is a leak from a hose next to the city inlet. It occurred once I turned on the city water. I turned the city water off, filled that storage tank and used the water pump. Unfortunately, this did not solve the problem as the leak would continue every time we used the sink. After reading other threads I'm still at a bit of a loss on where to locate my check valve and if the check valve is even the problem. Any advice on this issue would be greatly appreciated.
U3270 is offline   Reply With Quote
Old 11-16-2013, 07:03 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Check the gasket inside the "garden" hose. Where does the sink leak? Replace the valves inside the valves and faucet. Check valve should be inside the left rear near floor level. Also the inline pressure relief valve, which is probably not needed anyway.
Photos?
Old 11-16-2013, 12:02 PM   #3
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
I've had issues with my kitchen faucet spray leaking whenever I'm hooked city water or running from my tank? I have an 06 Bambi. My wife likes the sprayer so I may have to replace it. Anyone else had this issue? If so a fix? I've taken apart the sprayer and it seems to be ok. But, obviously it's not. The gasket looks fine?
Mj: "I'm on the road again"
Markj55 is offline   Reply With Quote
Old 11-16-2013, 12:09 PM   #4
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
My 06 Bambi sprayer leaked, according to PO. I had a new one put in. Apparently I could only get sprayer kind, I would have preferred plain faucet.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 11-16-2013, 12:51 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Where exactly is it leaking? Gaskets can "look fine" but still leak. Replacements are cheap.
Old 11-16-2013, 02:23 PM   #6
U3270's Avatar
1975 Argosy 24
Fullerton , Cali
The leak is coming from the hose right next to the city water inlet. It leaks when the water hook up is on or when I use the water pump. I'm trying to find the location of the check valve and wonder of it could be a different issue.
