Old 06-08-2016, 05:31 PM   #1
2015 23' FB International
2015 Interstate Coach
Trinidad , California
Larger fresh water tank ?
I own a 2014 23' International Serenity. I believe the fresh water tank size is 39 gallons.
Is it possible to install a larger size tank ? Is a larger one offered by Airstream ?
Thanx, Mark
Daddyfarless is offline   Reply With Quote
Old 09-13-2016, 05:49 AM   #2
Roadroamin's Avatar
2011 27 FB International
Algonquin Highlands , Ontario
I have the same problem, trying to conserve freshwater but it is the first thing that becomes a problem when boondocking. Looking forward to some feed back.
WBCII #7863
Roadroamin is offline   Reply With Quote
Old 09-13-2016, 06:39 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
While it is probably possible to add a larger fresh water tank to any Airstream, Airstream itself does not offer such an option and the cost of retrofitting an Airstream on which you are not already doing a frame off restoration would probably be unattractive.
We boondock most of the time (over 200 nights per year) and also have a 39 gallon fresh water tank in our Airstream. We also carry six five gallon plastic jerry cans (BPA free.) We will fill the jerry cans when we know we are going to be away from an accessible water supply and can make it seven to eight days with our 69 gallons (two experienced adults, no kids.) If necessary, we can make a run into town to get more fresh water in 30 gallon increments using the jerry cans which is good for about three to four more days.
The black tank usually fills up in twelve to fourteen days which is usually what makes us break camp.
Bob Martel
WBCCI# 5766
Old 04-14-2017, 09:27 AM   #4
Roadroamin's Avatar
After a lot of boondocking this winter we ended up buying a water bladder that can transport a lot of water when we need it. I use a pump to transfer from bladder inside the truck to the Airstream. Worked great.
WBCII #7863
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
Larger Fuel Tank rickandsandi Tow Vehicles 14 10-22-2011 09:21 AM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
Larger water tank Charlotte Fresh Water Systems 8 11-01-2009 10:04 PM
Going to a larger holding tank? Pacerized Waste Systems, Tanks & Totes 12 09-14-2008 07:53 PM
