Old 05-21-2018, 08:42 PM   #1
1968 28' Ambassador
Southwest Ranches , Florida
Keep gray tanks from sliding side-to-side
Hello!
I'm following the plans of some others on the forum and mounting my gray tanks with steel "straps" like the photo below.
The only thing that's coming to mind is how do I keep the tanks from sliding side-to-side, like between the main frame rails?
Any help would be much appreciated.
Nick
mashburn.nick is offline   Reply With Quote
Old 05-21-2018, 08:47 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Mine had styrofoam stuffed between them and the frame rails. I dropped the pan and pieces of styrofoam fell down all around. I have put the pieces back up and wedged them in tight.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-21-2018, 11:42 PM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
Tank spacer
If your dealing with small gaps, under 3/4", on some or all sides you might want to take a look at this. It a closed cell medium density foam with an adhesive back. It does not compress easily, but does have some give. I used it for some of my tanks that were close to the frame rails. You could also use it above the tanks to take up any slack.
http://www.rubbercal.com/s.nl/sc.1/c...Blend+w%2F+PSA
Harold & Rebecca
http://www.airforums.com/forums/f97/...er-172124.html
57Vintage is offline   Reply With Quote
Old 05-21-2018, 11:46 PM   #4
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
I shot a bunch of canned foam in the voids around the tanks to prevent shifting. Tite foam from Home Depot is a nice dense product for that.
TheGreatleys is offline   Reply With Quote
Old 05-22-2018, 02:26 PM   #5
1959 24' Tradewind
Twin Falls , Idaho
I used some expanded foam packing (not styrofoam). I got it from our IT dept, it's what HP uses to ship their computers. I thought I had pictures of it, but I think my better half has them. I'll post it up later today. Your layout looks just about like mine. I used Roxul and 1" foam board and Reflectix stapled to the floor. Here's a picture of my layout minus the packing on the side of the tanks
Anyway, it's pretty dense and it fits perfect in the channel of the frame.
Regards,
Tony
Trons4u is offline   Reply With Quote
How to keep sliding cabinet doors closed? AS2015Ser 2011 - 2015 International 11 02-21-2018 06:49 PM
Wardrobe Doors - To Keep or Not To Keep? Rhino33 General Interior Topics 2 10-07-2015 04:34 PM
Will the heat pump keep the tanks from freezing Riverdrifter Furnaces, Heaters, Fireplaces & Air Conditioning 25 12-12-2014 06:51 PM
Sliding screen door for the sliding door! weirdstuff Sprinter and B-van Forum 29 02-28-2014 09:19 PM
One way to keep the propane tanks secure switz LP Gas, Piping, Tanks & Regulators 1 04-06-2013 06:40 PM
