Old 06-13-2009, 05:43 PM   #1
chasrahm's Avatar
1970 31' Sovereign
Dallas , Texas
Is this what yours looks like? 71 31' Sov
Below is a photo of the waste dump connection. I've owned the a/s about 2 years and never had water hooked up nor used the waste system. I'm getting it water ready and don't have a sewer dump hose. I do have a 45 connector, but it wont go on because of the metal plate below the waste hook up pipe. In the photo, you can see the surface rust metal plate, the ground through a square hole cut in the plate, and the waste hook up pipe. The brown you see is West Texas sand/dust, not something gross.
What do I need here?
chasrahm is offline   Reply With Quote
Old 05-24-2010, 08:05 AM   #2
RaleighAir's Avatar
1973 31' Sovereign
raleigh , North Carolina
Looks like mine. I did notice the hoses that PO left for me don't connect. The fitting looks the same, twist to lock but I have several fitting and all are about 1/4" too small to fit my waste port. Did Airstream use an odd size fitting? I woudl think they're all standard.
RaleighAir is offline   Reply With Quote
Old 05-24-2010, 08:26 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
RALEIGHAIR: Airstream used Thetford fittings. They are slightly different in diameter than the Valterra fittings. Thetford fittings are available in most big RV parts stores, but stock is usually limited to complete fittings. If you ever find a place that sells individual gaskets, buy all of them.
CHASRHAHM: I assume we're looking into your rear bumper locker. It seems you need a 90 degree Thetford fitting. I don't know how you get it connected with a hose attached, maybe the square is wide enough. Unfortunately, I've never seen a 90 degree Thetford fitting, only 45. You can, however, find 90 degree fittings for the sewer end of your dump hose.
The Thetford fittings us the standard 3" sewer hose.
Zep
Shower manifold drips in the '70 31' Sov Intl chasrahm Fresh Water Systems 9 06-17-2009 08:09 AM
Upgrades for our '86 SOV coffeydelsol 1984 - 1989 Sovereign 3 03-23-2009 07:29 PM
75 31' Intl. Sov. univolt problems RandyG Electrical - Systems, Generators, Batteries & Solar 5 06-07-2008 05:07 PM
12v & 110 1969 Sov 31' CJ of Okla Electrical - Systems, Generators, Batteries & Solar 3 10-02-2007 10:50 AM
Our 1977 31' Sov. Midbath Marvel klayman Member Introductions 2 05-27-2006 07:15 AM
