Old 06-10-2016, 02:27 PM   #1
Tabasco's Avatar
1964 24' Tradewind
Stillwater , Oklahoma
Is this a Thetford connection?
Hello - 1964 Tradewind question:
This is what is on our black water tank. It measures 3 3/8" in diameter.
We have had trouble getting the sewer hose to seal properly. I did some reading and then ordered the Thetford to Valterra universal adapter, and that didn't fit quite right either.
Do I need a special hose? Some other sort of adapter? Help, please!
Tabasco is offline   Reply With Quote
Old 06-10-2016, 02:37 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
How is that connection connected up stream? If it is just a hose clamp or if you have enough distance to get a fernco, http://www.fernco.com/plumbing/flexible-couplings, fitting in there I would just upgrade to a current connection.
2004 Excursion 4x4
Old 06-10-2016, 02:44 PM   #3
Tabasco's Avatar
1964 24' Tradewind
Here's the only other picture I have of it at the moment.
Old 06-10-2016, 02:44 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Does not appear to be a Thetford fitting.
AtomicNo13 is online now   Reply With Quote
Old 06-10-2016, 03:42 PM   #5
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I've never seen a fitting like that. I suspect the best thing to do would be to find a modern fitting with the same pipe size, so you can cut that off and glue the new fitting over it.
What's the other leg of the "Y" for?
Old 06-10-2016, 03:47 PM   #6
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Looks like a thetford valve, but not sure about connection. Look at Inland rv website to see if you can identify the valve.
Cochese is offline   Reply With Quote
Old 06-11-2016, 02:31 PM   #7
1980 24' Caravelle
vallejo , California
I had a 64 overlander: there was a metal 90 adapter. Check ebay or craig's list. Or put a new adapter on your valve.
ke6gkv is offline   Reply With Quote
Old 07-16-2016, 01:29 PM   #8
Norm excella's Avatar
1971 31' Excella 500
Many , Louisiana
Looks like the smaller part of y may be grey water connection?? Not familiar with the end tho sorry?
Norm excella is offline   Reply With Quote
Replace Thetford with Thetford or Valterra? evansm1974 Waste Systems, Tanks & Totes 1 10-06-2014 09:01 PM
Thetford to black tank connection Can of beans Waste Systems, Tanks & Totes 0 08-26-2014 09:49 PM
Leaky Thetford Outlet Connection--How to fix? gquake Plumbing - Systems & Fixtures 5 12-04-2013 03:53 PM
Valterra to Thetford connection Craig Waste Systems, Tanks & Totes 30 03-05-2011 07:49 PM
Thetford Valve Connection to waste piping 77Overlander Waste Systems, Tanks & Totes 2 11-04-2009 08:27 PM
