Old 09-13-2019, 10:28 AM   #1
blickcd's Avatar
Milford , Ohio
Installing holding tank flush system on a vintage trailer?
Every now and then I think about installing a flushing system on my holding tanks, like what is found on modern RVs.
If anyone has done this and has some photos of the job they can post, or perhaps a link, I'd like to check them out.
Christopher
Its a camper, therefore it leaks.
blickcd is offline   Reply With Quote
Old 09-13-2019, 01:47 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We added a Tornado tank sprayer on our black tank when we did our restoration, Our trailer had no tanks, no interior skins and no floor at the time, so we added the new tanks while everything was apart. We could get to all sides to line things up so it was easy-ish to do. I don't know how you would do it if the tank is "in place"...or it isn't "perfectly clean" so the glue sets. Might be tricky...
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 09-13-2019, 02:24 PM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Flush King is the next best thing.
https://www.campingworld.com/flush-king-20522.html
Garry
Old 09-17-2019, 08:58 AM   #4
blickcd's Avatar
Milford , Ohio
Thanks for the replies.
The Flush King looks like the simple way to go, though I might need an adapter since my outlet connection is Thetford and I'll be the FK fits the more common Valterra.
Christopher
Old 09-20-2019, 05:52 PM   #5
Steamguy's Avatar
2019 27' International
Washougal , Washington
You might consider the method I've been using for decades:
  • Dump the black tank first (found out that Airstream calls it the 'Main')
  • Leave the black valve open.
  • Open the gray valve and quickly reach down and lift the dump hose above the level of the fitting, so the gray water washes into the black tank.
  • Count to about 30.
  • Drop the dump hose to the ground and quickly close the gray valve, leaving the black open.
  • Give the black plenty of time to empty.
Repeat twice, then close the black valve and open the gray, thereby flushing the dump hose.
Hope that works for you as well as it has for me...
Steamguy
2019 International Serenity 27 FB
"Live, Laugh, Love"
Click here to go to my blog: I try to add wisdom, not noise.
Steamguy is offline   Reply With Quote
Old 09-21-2019, 10:18 PM   #6
2007 22' International CCD
Sewer Solution system is very effective at tank flushing. Just twist the lever to send a jet of water into the tank or pump stuff out of it. Does take a fair amount of water. No moving parts and does not seem to clog either.
Black tank flush connected to fresh water system?!! Wconley Waste Systems, Tanks & Totes 25 10-17-2018 09:27 AM
Ouch! black holding tank flush issue jkinglet Sprinter and B-van Forum 45 03-28-2015 06:39 AM
No fuss flush black tank rinsing system" lloydnc Waste Systems, Tanks & Totes 21 04-22-2013 05:44 PM
How to add a b/tank flush system inthwind Waste Systems, Tanks & Totes 2 06-25-2003 09:59 AM
Black Tank Flush System Ed L Our Community 6 02-19-2003 08:36 AM
