Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 10-09-2009, 02:12 PM   #1
WILDRTEXAS's Avatar
Profile:  1970 27' Overlander
arlington , Texas
Send a message via Skype™ to WILDRTEXAS
In case GREY MATTERS...get it???
Have a 1970 AS without (as I have learned after purchase, not standard) Where would I install one? Can I install from below or above? What size should I get? Do I really need one? Can it just drain on the ground? Wondering???
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 10-09-2009, 02:37 PM   #2
kennethowens's Avatar
Profile:  1975 Argosy 24
Malakoff , Texas
That 1970 has not had one all this time.
On the ground....it is a "no-no" is parks.
They make a portable (from RV to dump-station) unit
ya pull behind your tow vehicle.
kennethowens is offline   Reply With Quote
Old 10-09-2009, 02:38 PM   #3
Profile:  2010 27' FB International
Mobile , Alabama
Its against the law in many states to dump grey water on the ground...Your tlr. had to have had one at one time...
Greg N Cindy is offline   Reply With Quote
Old 10-09-2009, 02:48 PM   #4
Profile:  1973 25' Tradewind
Chatham , Ontario
Our '73 Tradewind doesn't have one, and never did. The grey water has a bypass that drains it out the same outlet as the black water, after the knife valve coming from the black tank. Our plan is to get a 15 gal portable tank to connect there while set up, because it will be manageable to get into the back of the pickup after full, and thus not have to haul it around to dump. It really is nothing extra we will have to get because I want one anyway to take the stress off of the black tank for longer stays.
Airstream Project Picture Gallery
http://lorisart.org/gallery/thumbnails.php?album=34
BossCamper is offline   Reply With Quote
Old 10-09-2009, 02:49 PM   #5
Commercial Vendor
Profile:  Corona , California
Gray tanks.
Airstream "did not" install gray tanks in any model, until the 1974 model year.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-09-2009, 05:22 PM   #6
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 42
Live with it.
Get a "Blue Boy". a short dedicated hose and a dump cap with the hose connector built in. You will get used to "living" with the set up. Also get a longer, dedicated, hose for those time when you can drain the grey out and away. It really is not a big deal.
Old 10-09-2009, 11:22 PM   #7
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Semi related to thread...
California just switched their position on grey water dumping. It is now allowed under much looser guidelines than previously. The following is copied in part from an email I received in July from our building official.
Dave
"Yesterday the Building Standards Commission voted to pass the new California greywater code (Chapter 16 in the CA Plumbing Code).
This was passed as an emergency measure due to the drought and water shortages faced in the state.
Importantly, the CA department of Public Health spoke in full support of the code, citing water shortages and degrading quality of fresh water being a much greater health concern than any potential issue with greywater.
Summary of the new code (as it's written now) *no permit needed for a washing machine system if the system followed health and safety guidelines outlined in the code *no permit for a single fixture (one shower) if guidelines are followed *mulch basins allowed (instead of gravel).
*depth of discharge is 2 inches under mulch (it used to be 9" under dirt)
Other systems classified as “simple” and “complex” based on the quantity, will require plans and permits. "
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 10-10-2009, 05:57 AM   #8
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
We use a bluetote, the 22 gallon model, for dispensing of our gray and black water when we stay at parks that don't have hookups. It's got wheels and a long handle with a loop on the end you can use for towing the tote to the dump. I made a very short (1 ft disposal hose) to use when dumping into the bluetote.
When I boondock, I dump the gray water into the ground using a long garden hose.
Eventually, I'll have a graywater tank installed, but that's a low priority right now. Cost is what's stopping me now. A bluetote is about 130 bucks. Retrofitting a gray tank and rerouting the gray plumbing will cost about 1500-2000 bucks.
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
in case something needs to be fixed right now... janiemerle General Repair Forum 5 08-03-2009 09:56 PM
nt30 in nt22 case???? Raymond Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-18-2009 09:37 AM
Keep Furnace Case? 72BamaStream Furnaces, Heaters, Fireplaces & Air Conditioning 5 06-25-2008 08:13 AM
Just in case your in the bonnies tmcdougald Our Community 0 07-14-2005 11:30 PM
1957 basket case... p.dow 1957 Overlander 51 03-04-2004 05:25 PM
