Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 07-06-2007, 01:51 AM   #1
1Michigander's Avatar
Profile:  1975 24' Argosy 24
Midland , Michigan
I Broke the Greywater Dump Valve Handle
I recently purchased a 1975 Argosy 24. I got it for a pretty good price but the guy I bought it from did not know much more about it than I did. (I researched it on this forum before making my decision to buy it.) He gave me a general idea of how to work everything (or so I thought) so, before taking it on its maden voyage with my family of four I thougt it would be a good idea to "flush the system". It still has that pink stuff in it, which I am assuming is some sort of antifreeze/protectant. I removed the cap, hooked up the hose and proceeded to try to open the Grey Water Dump Valve. You know "Murphy's Law" says if it jams force it. If it breaks it needed replacing anyway. So I forced it. Of course, I broke it. Which made me say, "Oh gosh darn!" Now what? I removed some bolts which hold up the aluminum pannel and I can see where the handle should and does slide back into the valve but now nothing happens. It is my thinking that the valve needs rebuilding at the least and probably replacing. This brings several questions to mind after reading the string, Holding tank Valves.
1.) What is the best way to jack this thing up so I can get under it with enough room to work?
2.) My inclination is to remove this whole big sheet of aluminum across the rear of my Argosy because it is corroded in places and coming lose from the frame and replace it. Should I do that or just do a pach job?
3.) Should I just replace the valve or rebuild it?
4.) While I am under there should I replace the Black Water Valve as well for good measure? I do not think I want to do this twice.
Being a new AS owner and new to travel trailers altogether, makes me wonder whether I should tackle this job myself. Everyone in this forum has been so helpful I am hoping you will give me some sage advice on this matter as well.
If God had a refrigerator, your picture would be on it.
1Michigander is offline   Reply With Quote
Old 07-06-2007, 08:18 AM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
One of two ways. First is to hook up to your tow vehicle, and pull the trailer onto ramps made from stacked 2x6's until it is high enough to work under. Second way is to jack up the side of the trailer you will be working on, and lower the tongue to the ground. If you use this method, make sure you use a jackstand to steady and support it. Use wheel chocks to keep it from rolling.
2.) My inclination is to remove this whole big sheet of aluminum across the rear of my Argosy because it is corroded in places and coming lose from the frame and replace it. Should I do that or just do a patch job?
The belly pan is a pretty good size piece of aluminum sheet, why not patch it for now, and add it to your loist of things to replace when you get to it? You may need to go back in there at some point.
Since you broke it, you might as well replace it, as by the time you get the parts to replace what is broken, plus the parts to rebuild it, you will be close to the cost of a new valve.
The black tank valve, if it is also not stuck or jammed, would be a good candidate for rebuilding. You may as well renew both of them while you are there, you will then have a baseline for when it was last done.
You never know what you can do until you try. This is a relatively easy repair, consisting mostly of grunt work. If you get stuck, one of us here can probably talk you through it.
(No Longer at Inland RV)
Old 07-06-2007, 12:46 PM   #3
Midland , Michigan
Wow! Thanks! I thing the 2x6 idea is the way I will go. I would like to have the whole thing off the ground at once. Is it smart to go with these self tapping screws the previous owner used? Steel on aluminum leads to a corrosion problem. I was thinking of purchasing a rivit gun. It seems like it might come in handy more than a few times during my renovation of my Argosy. What are your thoughts?
I will replace both valves rather than rebuild them. I do not mind grunt work but it seems more like replacing both is a "stich in time". You are great, guys. Thanks a million. I will let you know how it goes.
Old 07-06-2007, 02:56 PM   #4
Well-Preserved
A rivet gun is mandatory when owning a vintage Airstream product, and one should be included in the purchase price.
As for screws, I hace had good luck using stainless steel screws, there is less corrosion with them as regular zinc plated screws. There is corrosion, but lots less.
Old 07-06-2007, 08:28 AM   #5
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Before you go though a lot of changes, if you just broke the handle you may be able to screw a long bolt into where the old handle attached and rig a replacement handle. On my 71 I thought I would have to take the trailer apart to fix, but a standard bolt screwed right in. I then attached an improvised handle to the bolt head end and it works just as good as the original.
Pay no attention to the man behind the curtain- WoZ
Old 07-06-2007, 09:39 AM   #6
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
I used a window crank handle with a set screw to fix mine when the plastic grey water t-handle broke off.
wacnstac is offline   Reply With Quote
Old 07-06-2007, 06:29 PM   #7
Profile:  1974 23' Safari
Phoenix , Arizona
If you have access to an air tank, Harbour Freight has a pneumatic riveter for $29.99 on line. I had to competely disassembly my bathroom to get the black tank out to repair a leak and the air riveter was a lifesaver....and hand saver.
Marv
Rusty9 is offline   Reply With Quote
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 02:01 PM
Sticking Dump Valve 74SovereignInt. Waste Systems, Tanks & Totes 12 10-05-2002 07:14 PM
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 0 10-02-2002 08:28 PM
Dump Valve Will Not Open Darryl Waste Systems, Tanks & Totes 1 06-19-2002 01:19 PM
Dump valve gwsullivan Waste Systems, Tanks & Totes 11 05-30-2002 09:38 AM
