Old 02-15-2014, 08:40 PM   #1
thinktankair's Avatar
1961 16' Bambi
grass valley , California
How tough is the top of the black tank
I have a sagging floor edge next to the toilet of my 1961 bambi. I have removed the kitchen and I can shim the floor against the top of the black tank. Is the top of the tank tough? Can it take the pressure of the shims holding up the edge of the floor. Thank you!!
thinktankair is offline   Reply With Quote
Old 02-15-2014, 11:03 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The top of the tank is not designed to be load-bearing. You're much better off shimming against a framing member, if there's some way to do it. I would only shim against the tank if your shim is actually a metal plate longer than the top of the tankó and more rigid than the top of the tankó so that the shim is supported on the edges of the tank, not the center of it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Can't remove the gas tank Buttercup Classic Motorhomes 14 12-02-2011 09:03 PM
Waste tank issues? 1969 Overlander edglenn Plumbing - Systems & Fixtures 4 10-04-2011 10:59 AM
Black water tank valve flange Safari64 Waste Systems, Tanks & Totes 1 09-22-2011 07:50 AM
I am having problems removing flange from black tank bennyg Waste Systems, Tanks & Totes 11 07-08-2011 07:19 AM
New black tank pan RaleighAir Waste Systems, Tanks & Totes 21 02-24-2011 06:00 AM
