Old 09-05-2010, 07:27 PM   #1
Ottawa , ON
How to unplug/unclog a black tank roof vent system
I am suspicious of my venting system for the black tank, and I want to make certain that there is nothing blocking it.
I've done a search and read a bunch about smells, hills, and blockages, and while there are lots of references to a blocked vent potentially being a problem, nowhere could I find a solution.
Oh, great readers, possessors of all and vast knowledgable , how may I be sure that the vent is open and performing its full and proper part in keeping the smellies out of our coach?
Your help is much appreciated in advance.
ps: grumbling to myself that I only replaced the screen and Vulkem caulking on all of them last summer...
Old 09-05-2010, 07:37 PM   #2
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Organic Solution
Step 1. Purchase beans.
Step 2. Boil beans until soft and add chiles* for flavor and to enhance result.
Step 3. Eat beans and chiles.
Step 4. Wait a few hours.
Step 5. Run yellow caution tape in a wife circle around trailer to protect children and the infirm.
Step 6. Sit on toilet while opening valve.
Step 7. Nature will provide the necessary flatulence to open the vent.
Glad to help.
Gene
*habañero chiles are very strong, may be unavailable in Ontario, but will certainly add to the explosive results.
Old 09-05-2010, 07:41 PM   #3
r carl's Avatar
Lin , Ne
If you suspect a bird or potatoe in the pipe you can just look down in it with a light. You could also run some water down the pipe to see if it fills up with a couple of gallons, if not its just going into the tank.
Old 09-05-2010, 07:42 PM   #4
r carl's Avatar
Lin , Ne
Glad to help.
Gene
Flushing a cherry bomb works too.
Old 09-05-2010, 09:04 PM   #5
Ottawa , ON
Glad to help.
Gene
Gene your help is always cherished, then folded and put away neatly. In any event, I tried something along those lines, but the reaction was noted rather vociferously, and it was "suggested" to me that untested experimentation along those lines would not be welcomed in future.
Yes, I had thought of that, but of course the pipe, which can be seen in one of the closets between the rear bathroom and the sleeping quarters, takes a left turn (45°) about half the way down its travel, thus making the light idea unworkable.
I guess that really, I'm hoping for solutions from those who have done this before as to what tools were used and which worked.
For example, a plumber's snake seems a bit of overkill, plus I'm concerned that it could damage the tank.
I'm also not wild about putting any fluids down the pipe either, since I don't see how that would dislodge something that might be stuck in there.
But thanks for your concern and humour so far, I'm still hoping for a magic bullet...
Old 09-05-2010, 09:09 PM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I put a snake down from the top when I thought the grey tank was not dumping fast enough, probably same construction for the black tank. Put a hose on full force and it flowed easy, no backup, replaced the valve and it still drains slow, on thinking about it, part of the slow problem is the tank shape, very long and flat compared to the black tank.
Old 09-06-2010, 12:16 AM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
The FANTASTIC FAN rumor is true
That's what I'd do too.
HOWEVER, there's a big caveat. I've heard that many SOB's just cut a hole in the top of the black tank, drop the pipe on it and put a little seal around it. THEN OVER TIME the vibration from moving the RV causes the pipe to slide down INTO the black tank, eventually getting below the level of the waste and guess what NO more venting except when you flush. Supposedly AIRSTREAM uses a fitting glued to the exhaust pipe to keep it on the top surface of the tank................................. now sure they did that in the good old days, but now?
My personal experience is that I know my vent pipe works. I had a second Fantastic Fan put in my bedroom... right next to the bathroom in the 25 FB. The mothership put in a bi-directional fan, and I LOVE to have it blowing on me when I'm boondocking in hot weather. Except when I flush the toilet. Thought I was gonna GAG. Now any midnight trip to the john is preceded by turning off the fan prior to flushing and leaving it off for about 10 minutes!
Having left you with that mental image, I'm going off list for now.
Paula
Old 09-06-2010, 01:18 AM   #8
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
On my 67 I thought the vent was plugged because of the foul smells. It turned out to be a dirty tank, cause its an old trailer I guess. I put ice in the tank prior to a few road trips and presto.....no more horrible smells. Adios, John
Diesel1 is offline   Reply With Quote
Old 09-06-2010, 05:15 AM   #9
Arrowstream's Avatar
Columbia , South Carolina
I had a black tank vent blocked solid by mud daubers. I would try pouring water down the pipe and if you get flow, flush it out with a garden hose. This method may also show if you have any poorly glued connections as water will shoot out of any bad joints.
Arrowstream is offline   Reply With Quote
Old 09-06-2010, 08:20 AM   #10
Master of Universe
Gene's Avatar
You can also flush from the bottom. Using a Flush King, flush all the black water stuff out of the tank. This can take quite a few flushes. When it's clean (you could chlorinate it), just keep filling the tank until water comes out of the top of the soil stack (the plumbing name for the vent pipe). It will cascade down the side of the trailer and probably dislodge anything blocking the pipe. Don't have the fan door open while doing this.
How do I know this will work? Some campgrounds have much higher water pressure than others. In some, 4 minutes backflushing will not fill the tank. In others 2.5 minutes will bring a picturesque waterfall down the side of the trailer. It is pretty clean as the solids stay at the bottom of the tank. The toilet seal should hold as the water pressure should keep it closed. Because the water is under pressure, any leaks will be discovered very fast.
I know this will be found disgusting by some, and I have never done this intentionally, but if you get the black tank really clean, it could open up the pipe, or give you a good story. If it doesn't work, there's always beans.
Gene
Old 09-06-2010, 09:07 AM   #11
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I am assuming that slow emptying of the tank is what is making you think it is blocked. I think it is more likely that a dam of TP etc is partially blocking the exit.
Do you have a way of observing the flow when emptying?
Fill the tank, and the watch the flow while emptying. Have someone open the flush valve in the toilet. If your vent is blocked, the flow should increase substantially.
If your vent is blocked, you should be able to hear the tank oil can (pop while flexing) while emptying, and if you have a clear section of pipe, you should be able to see a bubble go up the sewer pipe periodically, as that is the only source of air.
That's the end of my ideas.
regards,
Ken
Old 09-06-2010, 08:01 PM   #12
Ottawa , ON
Paula
Ewwwwww! I just figured that out! When you flushed, that blew some of the aromatic exhaust out the stack.
Of course, your supre efficient fan then sucked it right into your trailer.
Old 09-06-2010, 08:12 PM   #13
Ottawa , ON
I'm changing my mind on not wanting to do this. It does sound fairly safe, and there IS the added benefit of testing the pipe to make sure it doesn't have any leaks.
Gene
Gene, I don't know which is worse, this method (golden showers) or the "Bean Blowout" system. I'm afraid neither will get used.
ken,
No, my only complaint is that there is frequently a "disharmonious" scent present. I had a drain problem which was caused by over-use of paper, but that problem has been solved some time ago.
regards,
Ken
Well that makes sense, and since I never hear the oilcan effect, I am now thinking that there are three possibilities:
1) I am imagining all this
b) There is a blockage, but not severe enough to create a vacuum strong enough to make the tank oilcan, or
iii) There is a blockage, but there are also air leaks in the pipe joints, enough to offset the oilcanning.
I'm going to try a water hose in the soil stack from the roof, and will report back as to my results!
Thanks to all of you.
Old 09-06-2010, 08:12 PM   #14
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Gene
That's disgusting! Would it really come out the top? I'm just picturing the dump station at the campground with water spewing out the vent of my trailer. EWWWW!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
vent, clog
'76 Argosy have vent pipes at roof (nicro vent install idea) BrianD. Waste Systems, Tanks & Totes 6 11-08-2014 06:28 PM
Black/Grey tank roof vent failures silverback Waste Systems, Tanks & Totes 4 05-03-2009 08:32 AM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
Roof Vent Early Warning System - Save 1000's of $$$$ lebolewis Plumbing - Systems & Fixtures 7 10-17-2006 12:12 PM
Black & Gray Water Tank's Handles Stuck 53flyingcloud Waste Systems, Tanks & Totes 5 08-25-2004 01:09 PM
