Old 11-18-2002, 11:32 PM   #1
hex
hex's Avatar
Question How To Test Holding Tanks
Are there any tried and true ways to test the 3 holding tanks?
Is there any way to gently pressurize them to check for leaks?
How about dye?
hex is offline   Reply With Quote
Old 11-19-2002, 02:38 AM   #2
LOST , Hawaii
To pressurize the black and gray tanks you would have to seal the roof vents and all the plumbing drains. The fresh water tank has a vent that would have to be plugged. The plastic tanks aren't meant to be pressurized so even if you got everything sealed you wouldn't be able to use very much pressure and it wouldn't be much of a test with out some very accurate gauges. I would fill them with water and start looking for leaks.
John
74Argosy24MH is offline   Reply With Quote
Holding Tanks on a '99 Safari 25' ElliottBartlett 1999 Safari 11 08-01-2017 11:49 AM
Bambi holding tanks..HEATED..CONFIRMED dtbw 1997 - 2004 Bambi 3 06-30-2003 06:47 AM
1952 - no holding tanks? Cruiser Waste Systems, Tanks & Totes 20 03-10-2003 05:04 PM
Holding tanks smallfry Waste Systems, Tanks & Totes 2 12-17-2002 02:17 PM
My dumb question about holding tanks JaceBeck Our Community 6 12-07-2002 01:22 AM
