Old 03-24-2008, 08:00 PM   #15
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Hammer and center punch method
Success! I decided to try the hammer and center punch method before fabricating an airstream black hole wrench because I didn't have any angle iron lying around. The center punch method worked in this case. The black abs flange moved about an 1/8 inch with each tap of the hammer. So quite a few taps were require. Eventually the punch actually rounded out the taps in the flange. So I had to cut new tabs in the flange with a small hand saw. The black abs flange in this case had plastic threads.
ID:	56866   Click image for larger version
Todd
“Complications arose, ensued, were overcome...savvy?”
- Captain Jack Sparrow
monocoque is offline   Reply With Quote
Old 06-10-2013, 06:41 PM   #16
drifter45's Avatar
1988 32' Excella
Church Point , Louisiana
I have a 1988 Excella. Does the flange screw into the black water tank on that model as well?
drifter45 is offline   Reply With Quote
What's a '73 waste tank and toilet worth? vishwa Sinks, Showers & Toilets 1 08-07-2006 10:05 PM
Need flange for my toilet-b/w tank 68Glbtrotter Waste Systems, Tanks & Totes 7 01-24-2006 08:07 PM
Toilet Flange won't unscrew!! mello mike Sinks, Showers & Toilets 11 07-11-2005 08:34 PM
Galvenized waste box..how to remove? fly2havefun Waste Systems, Tanks & Totes 6 10-03-2004 10:08 PM
Toilet Flange Sneakinup Sinks, Showers & Toilets 16 06-30-2004 03:16 PM
