Old 02-27-2011, 06:17 AM   #1
1970 23' Safari
Alpharetta , Georgia
How to remove slip hub / flange 1970 3/4 bath
Hi, I'm trying to remove my black water tank on my 23' 1970 Safari to work on floor and tank repairs/replacement. The only thing from keeping me from removing the tank is this Thetford slip hub from the dump valve. It was clamped on with a pipe clamp which I was able to remove. It won't pull loose, should I use a heat gun? Should I keep pulling and twisting? Any tricks would be appreciated.
thanks,
Brian
silversafari is offline   Reply With Quote
Old 02-27-2011, 07:21 AM   #2
1970 23' Safari
Thumbs up Removed!
After some twisting, tugging, and pulling it finally came out.
Old 02-27-2011, 07:40 AM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Any "treasures" come with it?
Colin
Colin H is offline   Reply With Quote
hub, thetford, valve removal
Shell-off of a 1970 Silver Streak Sabre SSSabre Vintage Kin 35 02-17-2014 06:28 PM
Original hub caps, '70 Overlander. rayandre 1970 Overlander 11 08-05-2013 07:46 PM
Wet bath to shower? osolow Sinks, Showers & Toilets 6 03-24-2011 10:25 AM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 01:03 PM
