Old 09-08-2016, 07:23 PM   #1
aap
2015 23' FB Flying Cloud
Seattle , Washington
How to Protect Black and Grey Water Valves
Hey Everyone -
I'm looking into ways to proactively protect the black and grey water valves that are used to dump their respective internal tanks.
More specifically, it really bothers me with how low the valves ride even with my 15" wheels and lift kit. I'm thinking some type of frame which would protect the pipes against rocks and low points, but would not negatively impact the pipes or the AS frame.
I did a bunch of searching on the forum and online in general and haven't found anything just yet. I do plan on talking to my local dealer and AS proper to see what options they may have explored.
I'm thinking many of the folks here must have addressed this situation inn fashion.
Thanks in advance for reading and any advice you may have.
-anthony
aap is offline   Reply With Quote
Old 09-08-2016, 07:58 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have never read or heard of anyone doing anything like you ask. I just try to be very aware of what is going on around that area. So far so good.
MICHAEL
Old 09-08-2016, 08:23 PM   #3
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
Prior to my Alaska trip, I split a section of white plastic pipe lengthwise in half and attached it to the black & gray drain pipe. It is thin enough to bend and I used duct tape to secure it to the smaller pipe. The wide end extended out just far enough to protect the valves for rocks & stones. Later I used reworked it foam padding and clamps and spray painted it black.
Also consider protecting the water drain valve and the propane gas lines with plastic or foam coverings. Not problems after 8+ years. Good Luck.
JStanley is offline   Reply With Quote
grey and black valves need replacing, reduce to 1 valve? dcorona Waste Systems, Tanks & Totes 15 06-30-2015 10:20 AM
Black and Grey Tank Valves Hard to Pull Ssmookler Plumbing - Systems & Fixtures 2 03-08-2015 04:22 PM
Minuet Water Valves - What is What? Grey and Black ply5013 Waste Systems, Tanks & Totes 1 11-16-2012 11:04 AM
Black/Grey Water Valves - Drama on the road!!! AndyPenny Waste Systems, Tanks & Totes 1 07-19-2008 11:03 PM
'78 20' Minuet repair question: grey/black water drain valves Van All Argosy Trailers 4 01-06-2004 09:40 AM
