Old 05-23-2008, 08:12 AM   #1
1963 24' Tradewind
Acworth , Georgia
How to extend the waste valve hookup
Hey All, I am a newbie and have lots of questions. I just bought a 1963 24 foot Tradewind Land Yatch. My first question is how could I extend the waste valve from underneath the airstream to the side. It's not a very easy access connection, especially at the dump site when the ground is wet.
tincuplady is offline   Reply With Quote
Old 05-23-2008, 10:07 AM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You can cut the 4" exit pipe and extend it with another piece and a glue on union. Did that on the Excella. Much better to have it out where I can see it.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-23-2008, 10:51 AM   #3
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Extention
If you don't want too cut and glue, you can buy Valterra extention's from 5" to 15" in clear or black.
Gunny
Gunnyusmc is offline   Reply With Quote
Old 05-23-2008, 01:39 PM   #4
Road Ruler's Avatar
Images: 38
Tincuplady.. We have the same issue with our 73 Safari. At the dump station it is get out the cardboard and make a kneeling pad. Then get down and reach way under the trailer to attach the hose. It is a pain but really don't want to add a permanent elbow and extension as it would extend down quite low and one would increase the risk of bumping it and knocking it off or worse.
I would be interested in seeing some pics of what others have done to fix the problem. Pics anyone?? I know Doug "Shacksman" here in Ontario had done some interesting conversions.
63 Safari waste valve rebuild airstream4 Waste Systems, Tanks & Totes 19 06-04-2008 08:31 AM
waste valve 1963tradewin 1959-69 Tradewind 8 05-23-2008 08:27 AM
dual waste valve assembly urbanfood Waste Systems, Tanks & Totes 1 08-19-2007 09:57 PM
Waste valve handle Cochese Waste Systems, Tanks & Totes 1 09-30-2006 10:04 PM
Waste valve picture mtnman Waste Systems, Tanks & Totes 5 12-13-2005 11:09 AM
