Old 04-17-2013, 10:18 AM   #1
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
How Often Do You Dump the Black?
We've just taken ownership of a 2008 Classic 25FB and the black tank is enormous compared to our 15 gallon Casita black tank. Normally after a two day state park camping weekend we dump the black then the grey Casita tanks but the Airstream has a 37 or 39 gallon black tank. I would hate to waste so much tank chemicals. One bottle for 40 gallons but if the tank is barely full it seems a waste to dump it. Typically we go out once a month then take the normal 2 to 3 week vacation. If you are going just for an overnight or a weekend trip do you just put in enough chemical for about 20 gallon and then dump the black or if you know you are dumping in a couple of days don't bother with chemicals
If you are on the road do you just dump the black after 3 or 4 days or useage? The sloshing should be helpfull break up the solids.
We don't have the same issue with the gray because the Casita has 32 gallon gray tank while the Airstream only has 37 gallons.
Thanks for your insight.
Kelvin
Old 04-17-2013, 10:20 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The deodorizer part of the chemical stops working after a few days. Dumping it about once a week would be as seldom as I would want to go.
Old 04-17-2013, 10:26 AM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Ah, modern problems. Since I only have a tiny black tank in the Argosy (12 gallons or so) it never occurred to me to think in terms of big-honking-tank decisions. I dump the tank after every trip, which is usually 2-4 days. I use the "BioActive" enzyme stuff, and just use a few ounces because I know we're not going to fill even the small tank Friday-Sunday. I wouldn't want to store it without emptying the tanks, but considering the likely shape of your under-floor tanks, you'd probably want to run the tank-flush sprayer every time at the end of short trips.
— David
Old 04-17-2013, 10:29 AM   #4
timmaah's Avatar
1999 25' Safari
On , the road
We don't use any additives of chemicals in the tanks and try to dump as often as we can.
Only had a smell when we first started out and right after we dumped each time. Adding a gallon of water was enough to make it stop. It was hot then (mid 90s) and our tanks hadn't been used in a long time.
Right now it is day 9 since dumping. I'm hoping to make it two weeks, but I doubt we will make it.
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 04-17-2013, 11:00 AM   #5
1974 Argosy 20
Kooskia , Idaho
I live in a relatively cool climate, and almost never use chemicals in my black tank. I do have a small tank like DKB's but I usually can go a week without dumping (single here). If I do detect odors and it is hot, I add some chemical if the tank is partly full and it is not convenient to dump. That has always killed the odor, even added to a partly full tank.
I would try to dump the black tank about once a week, no matter how full it was, or what size it is, especially if you go sans chemicals.
Old 04-17-2013, 11:04 AM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
You'll find that opinions vary widely on the use of holding tank chemicals.
I use aqua-kem liquid, and use a 6 oz bottle after dumping the tank. It's not expensive and I prefer to use an entire bottle at once to avoid problems with spills.
I believe that the environmental problems with aqua-kem and similar products have been greatly exaggerated. Essentially similar products are widely used in the portable toilets for construction and special events, and by airlines.
We typically dump tanks when leaving a campground unless there either is no dump site or we're in a big hurry. I dump both tanks unless the toilet has hardly been used.
Old 04-17-2013, 11:38 AM   #7
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Being weekend campers, we've always dumped after a maximum of three or four nights, using something called RV Boss as an additive to keep things under control. RV Boss requires a 30 milliliter dose after each dump and that's normally good for that three or four days. We've never had an odour issue and the RV Boss, combined with the dishwashing water which usually gets put into the black tank as well, seems to reduce the waste to a brown soup almost immediately (I often check to see what's coming out of the slinky!).
That said, we've been using the Airstream on the driveway for about five weeks now, during some home renovation, but making a point of using the toilet lightly. It was only this week that I did notice an odour, so I ran down to the nearest dump station; the trailer now smells as it should, especially as I added some more dishwater and a dose of RV Boss. I may not leave it so long in the future!
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 04-17-2013, 01:27 PM   #8
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We normally dump after every trip, even if it's only a long weekend. However, if we are on a longer or multi-legged trip, we only dump when the black tank is at least 3/4 full. (Frankly, more often than not our dumping schedule is determined by the need to dump the grey tank. If we have to dump one, we go ahead and dump both.) After dumping, we put about 2 gals of water in the black tank and add the chemicals at that point.
As long as there is sufficient liquid in the black tank it's OK to let it stay there between trips ... if they are fairly frequent, but if the AS is not being used for several weeks, it's safer to go ahead and dump. What you want to avoid is solids building up in the bottom of the tank and drying out.
Also, your climate is a consideration. Odors will be more of an issue in warmer climates, and rather than let stuff sit there and "percolate" in the heat, we'd just as soon get rid of it. Also, hot climates may require more chemicals.
TB & Greg and Abbey Schnauzer
#3954
Old 04-17-2013, 05:03 PM   #9
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Rather than run down to the dump station, do you have a sewer cleanout plug at home that's accessible? Some places do; others have the cleanout plugs buried. If you have an accessible cleanout plug, then you have a dump station right there at home. That's all a dump station really is, a sewer cleanout plug that's accessible, with a hose alongside for rinsing a slinky.
Anyway, to answer KJRitchie's question, I dump my black tank on two schedules: (1) when the tank level monitor shows it's nearly full; (2) at the end of the trip whether it's full or not. To help control odors, after dumping the black tank, I generally use the tank flush fitting to refill it— right there at the dump station— with clean water, and then dump it again. THEN I dump the gray tank.
Especially during hurricane season, when my Airstream is my escape vehicle for evacuations, I make a point of storing it with completely empty gray and black tanks in case of an unscheduled boondocking opportunity when a storm is coming my way and I'm getting out of Dodge.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-17-2013, 05:12 PM   #10
MrUKToad's Avatar
Chatham , Ontario
Sadly, no. There's no sewer access at all, even in the street; if it ever backs up (and they do), it'll all have to be dug up in the front yard, which is something you see quite often in our neighbourhood. If that ever happens then I'll pay to have someone put a discharge pipe in.
Old 04-17-2013, 05:15 PM   #11
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
It's good to dump a full tank to get full flushing power so when we can dump we fill the toilet as full as we can by flushing it until it fills fuller and then empty it. We always add chemicals for a full tank but even that can be adjusted. Warmer weather or longer holding times require additional chemical for the sweet smelling effect.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 04-17-2013, 05:19 PM   #12
And when you do, you shouldn't ever need to dig up your front yard again, because you'll be able to use the discharge pipe for Roto-Rooter access for any future clogs. Win-win, in my book.
WBCCI #1105
TAC LA-4
Old 04-17-2013, 05:22 PM   #13
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The key is having enough liquid in the tank to carry the solids out of the tank. Typically with my 39 gallon tank in our Classic, we typically dump around day 5 if we aren't constantly on the move. The hotter the weather, the more ripe the tank will get as the waste gets cooking. If we are on a weekend trip, I will add water to get the tank to a minimum of 3/4 full and then dump before heading for home. I have no facilities at home to dump the tank.
We use non formaldehyde tank additives to help digest the waste and keep the odor down. We also have a spray cleaner built into the tank and will use it to flush out the tank a few times a year when camped at a full hookup site.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-17-2013, 05:30 PM   #14
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I dump the black at the end of each trip, each time I leave a campground with a dump station, or when the tank is close to full, which ever comes first. When I am set up for longer than a week with hookups, I dump black followed by grey every 3-4 days. I never leave any liquid in any tank when the trailer is not in use.
I occasionally, only when the weather is warm, use a small bottle of chemical in the black tank if I'm going to be in one spot for longer than 3-4 days without hookups. I never use chemical when the weather is cool or when I have hookups.
Alan
