Old 09-08-2014, 04:24 PM   #1
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
How often do I need to dump?
Maybe a silly question. My Airstream is in storage while I do some repairs to her. I have a full freshwater tank right now, and since there is no head at the shop, spending a whole day there working on the weekend means I'll eventually end up using the head in the Airstream.
Aside from the obvious of emptying the black/grey tanks when they are full, is it ok if I only empty it it out say every 30 days or so?
Or is there some rule that says you shouldn't go past two weeks leaving stuff in your tanks? Can't really find anything beyond emptying when full.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 09-08-2014, 04:28 PM   #2
r carl's Avatar
Lin , Ne
Just use a 5gal bucket with cat litter in it.
Old 09-08-2014, 04:30 PM   #3
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
As far as I know there's nothing wrong with leaving the black tank 'in use' as long as there is a good amount of liquid in it. If it dried out you could end up with trouble.
Stephanie
Old 09-08-2014, 04:34 PM   #4
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
I would pre-fill the black tank with some water ....4-5 good flushes if you plan on using it for solids, otherwise you should be fine. Also replenish the deodorizing packets every 7-10 days
Somewhat related....
After dumping at one location and before I leave for the next I'll flush 4-5 full bowls into the black tank and then send in a packet. While I'm traveling the water will slosh around and clean any residue left.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 09-08-2014, 04:40 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I wouldn't use it at all sitting still in a metal storage unit in Florida. Maybe a Porta-Potti and take it with you to empty every day.
Doug and Cheryl
Old 09-08-2014, 04:52 PM   #6
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
How often you need to dump depends on how often you need to dump.
Old 09-08-2014, 04:59 PM   #7
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Deep, man! :-)
Old 09-08-2014, 05:06 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
During repairs, indoors? Get a porta potty!!! There should be plenty in the bigboxstores with huntin seezon upon us.
You could put it in the AS bathroom area for some privacy.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-08-2014, 05:43 PM   #9
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
When you are working in your trailer and your eyes start to burn it is time to dump.
thehandyman is offline   Reply With Quote
Old 09-08-2014, 05:44 PM   #10
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Astronauts use depends, truckers use wide neck bottle AS and most others designed better black water tankage than grey. If you are the only one using and can keep it to one flush, you should be fine for 30 days, if it is stored outdoors, might be a problem in a closed space unless it is well ventilated.
Old 09-08-2014, 06:28 PM   #11
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
No doubt you can store it, but should you?
If you use the head and dump the tank only every 30 days in the south where the weather is warm, you are inviting flies down the vent, maggots growing the tank, and hatchlings finding their way into the trailer when the dump blade opens. And that moisture attracts roaches, water bugs, ants, etc, etc. The bugs attract lizards and tree frogs. They all want in and the stuff in the black tank is a picnic.
I would not, but if you decide to use it, also use a good tank treatment that will keep the varmints out and odor under control!
I'm in mid FL 3-5 months per year. 4-5 days is long as I go between dumps.
Alan
Old 09-09-2014, 09:39 AM   #12
Nomadic , USA
Um.. indoor storage, fantastic fans running, storage has exhaust fans in ceiling running every time I've been there.
I'll take the different opinions under advisement.
Old 09-09-2014, 09:55 AM   #13
dkottum's Avatar
The black tank is vented out the top of the Airstream, it's going to stink inside the storage unit and you don't want that to dwell, perhaps for a long time, in your Airstream.
Doug and Cheryl
Old 09-09-2014, 10:18 AM   #14
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
When we bought our trailer, it was in Mississippi. The PO's had owned it for a couple of years and never used the systems. The fresh tank was full so we emptied it before leaving MS. In the disassembly process, we discovered the black tank was also full. When I drained it, no odor, just dark brown liquid. It had been there a LOOONG time! Grass grew well in that spot for the summer....
SO, if you leave it long enough it will "compost" for you.
BTW, I wouldn't leave the fresh water tank full for a long period. Our fresh water tank was green when we removed it. Algae.
Kay
How Often Do You Dump the Black? KJRitchie Waste Systems, Tanks & Totes 66 04-23-2013 12:30 PM
How often do small TT owners use the inside shower? Rog0525 Sinks, Showers & Toilets 32 09-23-2006 03:33 PM
H20 heater: drain how often? TomW Water Heaters, Filters & Pumps 14 10-10-2004 11:22 PM
How often do you use your Airstream? kamadeca On The Road... 7 03-25-2003 08:21 PM
Water Pump cycles often Guitars Water Heaters, Filters & Pumps 3 11-19-2002 08:04 PM
