Old 05-17-2007, 06:35 PM   #1
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
How Much Sewer Hose To Carry?
We are fairly new at ASing. So far have found 10-15 feet of sewer hose to be plenty. Any experience where more might be necessary?
henw is offline   Reply With Quote
Old 05-17-2007, 06:38 PM   #2
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
I only have 10' and plan on purchasing a longer hose as I've found that sometimes the distance between my trailer and the dump hole is longer than 10'.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 05-17-2007, 06:43 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
About 50'
Actually I use a normal slinky for the most part, 15' works in 95% of the situations. I also use a Sewer Solution which is an awesome product. I use this a lot at home when I have multiple "guests" spending time. I only have one place to dump a black tank, so we hook up the SS and empty one person at a time, and just move the pipe and hoses around
Aaron
WBCCI #XXXX AIR #2495
Old 05-17-2007, 06:44 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
10 to 15 feet typically does it for me. I like the heavy duty ones too cause it's NASTY when things go wrong.
Old 05-17-2007, 06:51 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I use the 15' hose, heaviest duty you can get. It will still tear, just will take a while.
I also have one spare in the box, in case the unmentionable happens while dumping.
Old 05-17-2007, 06:51 PM   #6
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
We've had to go and buy more where it is a particularly long run from the connection to our valves and that was at a luxury rv resort. Sometimes it is necessary to cross under the Airstream and that takes a good length of hose. You also would need many lengths to have "full hook-up" at the International Rally coming up in Perry Georgia.
We travel with a regular short length which is good the majority of times. If we cannot connect we back up or pull forward and use our full hookup as a personal sanitation station when we are ready to leave or drive to the main dump station where the short hose is more than ample. Having a connector and extra length could be a convenience, or it could be an inconvenience. If you have room stash another somewhere, it helps if you do not want to get the hose out to see how far it will stretch to know where you can park. We carry a cap to allow a grey hose to connect and have 50' of grey hose to connect for discharging grey water. The size of our holding tank for black water is more than ample.
We have the rhino hose now, it is heavy duty and you don't need supports as it is bendable and rigid and will expand or contract and keeps it's shape for elbows, etc.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 05-17-2007, 06:56 PM   #7
Aluminut
2004 25' Safari
. , Illinois
Originally Posted by wheel interested
We've had to go and buy more where it is a particularly long run from the connection to our valves and that was at a luxury rv resort. Sometimes it is necessary to cross under the Airstream and that takes a good length of hose. You aso would need many lengths to have "full hook-up" at the International Rally coming up in Perry Georgia.
....ah the joys of an FB unit!
Old 05-17-2007, 07:04 PM   #8
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
You mean you can use a hose...you mean I don't need to use a bucket?
Once worked aircraft "fleet service" in Incirlick Turkey. Not a pretty sight when one of my guys opened the service port on an aircraft only to discover the dump valve had been frozen open. Not pretty at all...it was funny...but only from a distance
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 05-17-2007, 07:16 PM   #9
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I carry 40 feet in two 20 feet sections. THe First has the Trailer coupling adn the second has the connector for the two hoses. I have used every inch of the "40" feet at least twice.
Michelle TAC MT-0
Sarah, Snowball
Old 05-17-2007, 07:20 PM   #10
Well Preserved
1993 21' Sovereign
The voice of experience here. Happened to me on an SOB MoHo. The yard stank for a week and a half. Maybe one reason why they call 'em SOBs.
Old 05-17-2007, 07:22 PM   #11
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I carry a 20' hose. I've had to extend it close to its max a few times. I never can quite figure out those sites who have the sewer outlet up towards the front.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-17-2007, 07:26 PM   #12
Well Preserved
1993 21' Sovereign
Jack
Jack, I haven't yet had the pleasure of staying at one of those. Maybe they were intended to be pull-through sites, or coming in from the opposite direction, and got altered at some point.
Old 05-17-2007, 08:17 PM   #13
jcanavera's Avatar
Fenton , Missouri
Images: 143
Interestingly enough many are pull throughs, but the utilities are on the same side so I know I've come in the correct direction. I've also run into some of these in back in sites also. So the longer the trailer the further you are away from the sewer line. Maybe they assume that we all have fifth wheels where a lot of the outlets are mid trailer.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-17-2007, 08:35 PM   #14
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Sewer Solution
Just got one of these, only way to go in my opinion, easy to clean, stow and run longer hose. And it will pump uphill! And if you had to you could use it as a scatter gun to learn manners to an unruly campground host, but that's in another thread huh. Check out the afore mentioned link, this thing works as advertized. DG
Name:	86 Excella 137.jpg
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Fred vs. Hose Reel ViewRVs Airstream Motorhome Forums 10 09-01-2007 07:34 PM
Sewer Hose length? AirHog Waste Systems, Tanks & Totes 16 04-21-2004 01:39 PM
I want to connect permanently to local sewer Jaime Esparza Waste Systems, Tanks & Totes 1 09-09-2002 08:49 AM
Sewer Solution tomb Waste Systems, Tanks & Totes 4 08-29-2002 05:43 PM
LP Hose from Reg. to Trailer niftypkg LP Gas, Piping, Tanks & Regulators 2 06-20-2002 09:09 PM
