Old 08-29-2010, 01:49 PM   #1
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
How is the black tank held in place in a '64 Globetrotter?
I'm replacing some of the flooring under the bathroom in my GT, a patch rather than a whole rip out the bath and redo, at this point. The black tank appears to be held in place, or had been, by two pieces of 1" plumbers tape slung underneath it. Those are gone, and my next project is to take the belly pan off under the tank and weld in place some steel strapping to support the tank, Any thoughts are welcome. Pictures to follow.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-16-2014, 11:13 PM   #2
64Lincoln's Avatar
1964 22' Safari
Sacramento , California
There was a sheet metal cradle that the tank sat in. My was quite rusted, but there was still enough metal there to securely hold the tank. I don't know if plumbers tape would give it enough support or if it needs support. It seemed quite ridged to me when I was working on mine.
64Lincoln is offline   Reply With Quote
how are the black and gray storage tanks held in place? gmwelder86 1974 - 1979 Sovereign 2 05-26-2010 11:28 AM
where is a good place to get a new water tank? Globie64 Fresh Water Systems 19 04-04-2010 07:52 AM
'70 Globetrotter Fresh and Black tank Capacities Arizona Al Plumbing - Systems & Fixtures 7 12-26-2009 05:55 PM
Removing Black Water Tank in 1971 Globetrotter ACUS1 Waste Systems, Tanks & Totes 4 06-14-2006 03:56 PM
what holds black water tank in place tw64 1959-69 Tradewind 3 06-16-2004 11:05 PM
