Old 08-01-2016, 01:37 PM   #21
in the rising sun toaster
1956 26' Cruiser/Overlander
Wimberley , Texas
"...if the water is used at home without fear, then it wont suddenly become dangerous in the tank of an Airstream..."
Agreed, wholeheartedly so, and also agreed that one's private wells *should* be regularly tested to alert to any/everything currently testable. This testing runs about $200 at Texas State Univ's Edwards Aquifer labs in San Marcos, a very reasonable cost for the knowldege gained.
My 2 untreated house wells in central TX, each aout 600' deep, have always passed EARDEC lab's exhaustive testing. I submit samples at least once annually (they remind me by email ), more often when judged needed, such as after HUGE rain events. My other place in the southern NM mountains has untreated Spring water, but the neighborhood water association also submits samples for testing regularly - but, not with the same glowing results as at my own wells in TX because this spring water is regularly contaminated by e.coli and other unwelcome life forms. It is also INCREDIBLY HARD water with various and sundry elements and minerals - this is very typical of ground water in this entire region of the country.
Even with regular testing and/or boiling w/ filtering, I still won't drink from them, or from any other unverified source, and I haven't for decades now. Several reasons/preferences: (1) I can't know what *today's* contaminates might be, (2) when traveling away from either home, it's impossible to do more that WAG about the safety of whatever water supply is encountered, (3) one bout of life-threatening water-borne illness (overseas/tropics, many years ago) was more than sufficient for me to learn the risks one takes w/ drinking local water, and (4) personally/anecdotally, I *used* to have at least one attack annually from kidney stones (due to more Ca+2 and Mg+2 than my system can process correctly) but, since switching to only distilled drinking water, no stones, none, nada, zilch, zero - also no apparent water borne illnesses for me and mine. Cause and effect? I'm concluding so, but perhaps just a very lucky correlation for me and mine for the last 20 years (Not!)
Btw, minerals that are necessary for healthy life *don't* have to come from one's water supply; were that always true, then the hundreds of millions of folks worldwide who rely solely on rain water would have obvious health issues. Rain is nature's distilled water supply, yes, admitttedly, w/ a range of purity levels, depending on many other envionmental factors. A balanced diet is really all that's required for all required nutrients, and for those who choose to, or for those who need to, using absolutely pure distilled water and perhaps also adding a daily supplement, like the Centrum Silver I take, are my "controls", my preferred substitutes to unknown water.
Not prescriptive. Not proscriptive. YMMV.
rsjmcg is offline   Reply With Quote
Old 08-01-2016, 02:26 PM   #22
2015 22' FB Sport
Wethersfield , Connecticut
Water supply systems throughout the US are regulated based on thier distribution as a public or transient population use and size. This includes camp grounds but typically not residential systems. The residential system typically gets tested during a property transfer because of the lender and it is usually only a potability study. As suggested by others if your concerned enough to want to add chlorine you should first test the supply system for at least potability. Keep in mind that by adding chlorine you are adding a chemical which in turn can create other chemicals such as trihalomethane all of which are monitored for in public water systems.
Also, in spite of the testing requirements not all supply system are compliant as we witnessed by the Flint Michigan incident. So if you know your home water supply is okay, this is a lot more info than you have on the various campgrounds you visit.
TinkersToy is offline   Reply With Quote
Old 08-01-2016, 04:34 PM   #23
2000 30' Excella
2014 30' Classic
Princeton , Iowa
Just for what it is worth, we have a well with very good water, I do not use any thing to treat it. I drain my fresh water tank before every trip.
I was raised on untreated lake and well water that was good water and it was never treated.
larryglarson is offline   Reply With Quote
Old 08-01-2016, 04:40 PM   #24
This has been a very interesting topic and I've always been interested in a water distiller. I haven't heard any one out there using one of the Burkey water filters. Anyone have an opinion if this would be an acceptable option for obtaining clean and safe drinking water from unknown water sources like campgrounds.
n9hox is offline   Reply With Quote
Old 08-01-2016, 11:38 PM   #25
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
Lived with surface well for 25 years and never had any problems (tested it and no health issues)... we run all water into our holding tank and also for connected use thru a household carbon filter, and almost always drink from our tanks. Santize the tanks once/twice a year.
rucos is offline   Reply With Quote
Old 08-02-2016, 11:58 AM   #26
2016 30' Classic
Santa Rosa , California
Here's a great bleach dilution calculator:
https://www.publichealthontario.ca/e...alculator.aspx
According to this calculator, if you want to make 40 gallons of water with 2 ppm chlorine using a 6% bleach, you need 5.3 ml of the bleach. You can plug in your own particular bleach concentration and desired ppm to calculate your own results.
I believe city water systems employ less than 4 ppm chlorine in their water since levels above that may make the water smell/taste like chlorine, and higher levels may not be healthy.
Happy Trails,
Phil
phann is offline   Reply With Quote
Old 08-02-2016, 12:46 PM   #27
2016 30' Classic
Burkey filters
I have used the Big Burkey at home for 4 years to filter our well water - primarily for use in my coffee maker and as an emergency water filter. Since it takes a few hours to filter a full 2.5 gallons, I keep a few empty gallon water containers that I fill from the Burkey when its done, then reload the Burkey with more water to filter the next batch. I use the basic 2 ceramic filters it came with, but could add 2 more if I wanted. I understand they also offer other filter types - for removing flouride, and other such elements.
It would work well for you in your AS to filter well water or campground water. Heck, you could even use lake or stream water! The only downside I see is that it would take up some counter space and/or storage space in an AS, and you would have to empty it when you are on the move. I would use it in our AS, but my wife prefers bottled water and more counter space - of course, my vote doesn't count....
Happy Trails,
Phil
Old 08-02-2016, 02:04 PM   #28
Zil
Curtis Wright
Eyren Haven , South Jersey
I think you know your well water at home is safe to drink. But filling the RV tank could introduce contaminates. The most dangerous of these introduced contaminates would likely be microbial. Therefor a chlorination practice is desired. In the industry we use total coliform bacteria as the target test as they are the easiest to quickly detect. If they are detected, then E. Coliform is tested as they indicate intestinal bacteria, and possible pathogens. Proper chlorination will defeat the bad bugs.
Zil is offline   Reply With Quote
Water Leaking at Wheel Well when water is hooked up Lauren25 Plumbing - Systems & Fixtures 18 12-28-2017 09:34 PM
Well, well, well...you'll never guess what followed us home today! InsideOut Vintage Kin 85 11-28-2017 08:58 PM
Well water in fresh water tank WisePharm Fresh Water Systems 19 04-18-2014 08:33 AM
Well, Well, Well........ Jim & Susan Off Topic Forum 54 06-12-2005 01:46 PM
