Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 10-23-2007, 08:47 PM   #1
1999 25' Safari
Sebastopol , California
How do you clear a stopped up black water tank?
I set up my trailer and connected it to the septic tank. The first few times I dained the black water tank, no problem. Now when I pull the drain release, I don't hear anything coming from the black water tank. Its like it plugged up. If it is plugged up, what can I do. Should I insert a hose from the toilet end? Or up the drain pipe end? Please help as the tank is filling up.
Aluminumb is offline   Reply With Quote
Old 10-23-2007, 09:00 PM   #2
_
hi aluminumb...
it has worked b4....
http://www.airforums.com/forums/f444...ank-31189.html
let us know how it comes out and be brave...
post pictures!
cheers
2air'
Old 10-24-2007, 04:56 AM   #3
1992 34' Excella
Punta Gorda, , Florida
All stopped up
Two things that should work. The "Magic Wand" that you put down the hole and swish and swish will help but after that make sure your grey tank is full. With the black tank valve open release the grey water. The sudden rush of water will pull any plugged up black water problem with it. I've been able to help several folks here in our campground with the same problem. Let me know. After the "Fix" is complete, make sure your black valve closes all the way. If it leaks a wee bit your problems will continue. Good luck.
FlaAirstream is offline   Reply With Quote
Old 10-24-2007, 06:26 AM   #4
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Originally Posted by 2airishuman
hi aluminumb...
post pictures!
cheers
2air'
Arghhh! No pictures please!
Try filling it with some warm water and then drive around with the trailer to "stir things up".
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 10-24-2007, 07:16 AM   #5
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
I cleaned out my black tank by putting in a couple of gallons of water with 10 pounds of ice cubes, then pulling the trailer for about an hour. Unfortunately, my tank was bad and I made a mess at a truck stop...
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 10-24-2007, 07:26 AM   #6
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
One quick comment - is the rod to the actual valve body pulled free? Some rods are threaded into the plastic slide and have a tendancy to strip out and not actuate the valve. You may think you are operating the valve and pull the rod but it may not be open.
Just a thought.
And I second the "no pictures" request......
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-24-2007, 07:28 AM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Do what lew said
Lewster said it right in his post #5 located in the thread mentioned above.
Its worth NOT having all the potential problems and mess by just calling a pro RV pump out service. They know how to get it clean with no mess. Cheap by any measure.
Old 10-24-2007, 08:48 AM   #8
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Okay, there is a do-it-yourself movie out there on just that subject involving air pressure and friends. It stars Robin Williams and is called "RV". Its a hoot!
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 10-26-2007, 10:34 AM   #9
1999 25' Safari
Thanks to all who gave input on how to clear the tank. It turned out to be easier than I expected. Following your advice, I filled the septic tank to the top, I filled the grey water tank to the top. Then I let them both go simultaneously and whooooooshhhh. It all came a tumbling down.
Ben
Old 10-26-2007, 12:11 PM   #10
1992 34' Excella
Ben.
Glad to hear it worked. Like I said, I've seen it do the trick several times. Keep the threaded rod in mind each time you dump. I gently tap my black rod with a rubber mallet each time I close to assure it's seated all the way. The "Brown Mountain Blues" is no fun. Happy dumping.
Black Water Tank robertpeters Waste Systems, Tanks & Totes 13 06-13-2007 06:26 PM
need new black water tank KHarris Waste Systems, Tanks & Totes 4 09-24-2006 08:34 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
Black Water Tank David Hall Waste Systems, Tanks & Totes 3 12-28-2003 07:24 PM
