Old 10-18-2013, 04:06 PM   #1
Aptos , California
How do I drop the black tank?
Hi all,
My 65 safari has a black tank leak. It's coming from the tank, not the valve. Any advice on how to drop the tank would be helpful.
Dave
farmerdave is offline   Reply With Quote
Old 10-19-2013, 05:32 PM   #2
Aptos , California
Anyone know?
Old 10-19-2013, 05:39 PM   #3
reinergirl's Avatar
Hollis , New Hampshire
Is your black tank below the floor? In my 1963 the black tank was above the floor and thus could not be "dropped". You'd have to remove the toilet and access from above
reinergirl is offline   Reply With Quote
Old 10-19-2013, 05:40 PM   #4
Ottawa , ON
I'm sure someone does, it just seems quiet this weekend on here.
Isn't yours above the floor in the rear of the TT? The toilet seat is set right on it, IIRC.
While you're waiting for other advice, I would empty it and rinse it a few times. Could you post a photo of it? Dying to know if my memory is playing tricks on me, or..?
Old 10-19-2013, 06:15 PM   #5
Aptos , California
It's under the floor at the rear of the trailer.
Old 10-19-2013, 06:17 PM   #6
Aptos , California
The toilet is between the floor and the fiberglass "bench".
Old 10-19-2013, 07:29 PM   #7
Ottawa , ON
Well, in the absence of any other answers, here's what I would do:
Look to see if the tank will come out from the top (inside the trailer) or the bottom (outside and under the trailer). The bench might come off, so look for riveted-on trim strips, behind which are seams. Those would typically have an assortment of screws and rivets holding them on.
Remove the trim, and just keep going.
Of course, someone will come along at some point who has done it and give you the exact method of getting at the tank, so if you'd rather, then just hang in there.
How about some photos of the "bench"?
Old 10-19-2013, 08:33 PM   #8
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
I did it on my 64, so will probably be similar. The black tank sits in a galvanized box, which is probably rusted out. You need to cut back the belly pan to expose it. Then remove bolts holding the box to the frame. If the toilet has been removed the tank should come right out. Problem is re-installation of the box is a challenge if you don't have access to the frame from above to install new bolts.
kevinb is offline   Reply With Quote
Old 10-19-2013, 09:24 PM   #9
Aptos , California
So the only thing holding the tank up is the pan? That doesn't sound too hard. It will probably prove otherwise, I suspect.
Old 10-20-2013, 12:46 AM   #10
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
The only thing holding our (1964) tank in at the moment is the pan, and the toilet flange, since the galvanized box is all but gone (we camp with full hookups and a composting toilet and bypass the tank). I want to replace ours and figured I'd bolt a couple of 1/8" steel straps under it, from side to side and bolted to the frame.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 10-20-2013, 06:52 AM   #11
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
Not hard but dirty. It just rests in the box, no other attachments. You will also have to cut the vent pipe from above.
Old 10-20-2013, 06:55 AM   #12
mandolindave's Avatar
My black tank was cracked when I bought it.
The shady used car dealer, who I bought it from, used the trailer as an out house.....all winter long.
Anyway, the toilet mechanism was badly rusted. I took it out and rebuilt it, and made an appointment for a restoration company to replace the tank.
The restoration company made a patch in the belly so that I would have access, so if I ever had problems, I would have easy access, so I have that going for me.
While waiting for the repair, I used a porta potty. After the repair was finished, I missed the port potty ( yeah eeewww, I should have worded that more better ) The porta potty was so much more convenient than the built in toilet. I could empty it in a porta john in the middle of a festival, or in my toilet when I got home. I never had to drive around looking for a dump site. I never had to pay $10 to dump. I never had to deal with a dirty hose.
I never stay at campgrounds or have hook ups. If I had it to do over again, I wouldn't have paid for the repair. As for resale value....I have no intention of ever selling the trailer.
mandolindave is offline   Reply With Quote
Old 10-20-2013, 07:12 AM   #13
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Black tank pics
Farmerdave,
The black tank is supported in place by the tank pan. The toilet, toilet flange and vent must be removed/disconnected as well.
Here is a link to pics of a 1966 Safari that I worked on with the same black tank/toilet configuration as you have.
1966 Safari
Good luck!
Lance
Top is offline   Reply With Quote
Old 10-20-2013, 07:26 AM   #14
KAYAKAMPERS's Avatar
1966 26' Overlander
Stone Mountain , Georgia
I removed our tank from our '66 Overlander. The tank pan was pretty well rusted , but the tank was OK. Disconnecting the tank from the toilet, grey lines to it ( if applied ) and the vent. Once the skin and rusted tank was gone, it came out easily for cleaning and storage while I rebuilt the steel tank pan. Our floor needed work and yours will likely too. Be prepared for a new pan, floor repair and skin replacement. These tend to work hand in hand.
_______________________________
Beth Wallace & Chris Sanor
1966 26' Overlander International
Towed by 2016 Ford F-150
Tin Can Tourist
TAC #GA-27
AIR #34930
KAYAKAMPERS is offline   Reply With Quote
Black Tank Replacement '73 Tradewind Placing in Frame - ABS vs polyethylene constructor Waste Systems, Tanks & Totes 12 04-07-2013 09:22 AM
Grey tank for rear bath '66 TW. FreshAir Waste Systems, Tanks & Totes 15 02-13-2012 09:06 PM
Need Black Tank Information! Janie Q Waste Systems, Tanks & Totes 6 06-07-2011 03:40 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
New black tank pan RaleighAir Waste Systems, Tanks & Totes 21 02-24-2011 06:00 AM
