Old 06-22-2010, 10:03 PM   #1
2018 25' Flying Cloud
Lakeway , Texas
Send a message via AIM to Acker997 Send a message via MSN to Acker997 Send a message via Yahoo to Acker997
How can I repair or replace sewer hose storage pipe?
I managed to damage the opening to the sewer hose storage pipe underneath my Airstream International 2005. I subsequently lost the cap because it would no longer seat securely. Does anyone have any ideas on a way to fix it? Or, if I have to order a replacement storage pipe, where to order it from? I tried to do a Google search with no luck on this particular part... Thank you!
Acker997 is offline   Reply With Quote
Old 06-22-2010, 10:12 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the forums. We're glad to have you with us.
They sell the storage tubes that you are looking for t Camping World. They are available in several different lengths.
Brian
SuEllyn & Brian McCabe
Old 06-24-2010, 12:59 AM   #3
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
My trailer had two installed when I bought it used. One had been damaged due to the right rear tire throwing a tread.
There is a thin wall white water pipe sold at Home depot and maybe even at Lowes that I was able to use. Cut the damaged end off, bought a section that was threaded and a screw in end cap.
Only problem was my sewer hose couplers are thetford and it is larger than the black plastic. Had to file out a ridge inside the new end section but, it worked.
This is not the 3000psi white thermo plastic but, a thin wall lighter guage stuff that is used for water.
Took a little while in Lowes / Home depot to work out the details but, it fits on the existing tubing.
I carry one 10ft and one 20ft hose.
Mine may be older than yours so there might be an issue.
wingfoot321 is offline   Reply With Quote
Old 06-24-2010, 04:35 AM   #4
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
The end cap on ours came off recently and I purchased two new tubes with end caps and all the hardware at Camping World. They had three different lengths of tubes so now I have an extra tube for a spare sewer hose. I reinforced the attachement with straps similar to radiator hose clamps which I screwed to the bottom cap of the trailer.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 06-24-2010, 05:44 AM   #5
fltlevel510's Avatar
Between Here , And There
Sewer hose storage tube
Acker,
Try doing a google search on "Valterra Hose Carrier" these seem to be the most common brand available. If you go to the Valterra Products, Inc. you will find not only the hose carrier but various repair parts for existing tubes.
Good Luck!
fltlevel510 is offline   Reply With Quote
Old 06-24-2010, 06:43 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you want cast aluminum try H Hull 260 668 5671. They also have aluminum wheel chocks and tongue jack stands.
Old 06-24-2010, 07:07 AM   #7
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
I'd like to see the cast aluminum hose carrier. Have any pics?
SilverHoot is offline   Reply With Quote
Old 06-24-2010, 07:53 AM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
No photos right now. I got mine on Ebay for $70. It was a family business, no longer in production so there were a few left. Consists of 4 parts. A cast head piece with latch, end cap, center support, and aluminum mounting plate. You supply the tube itself.
Old 06-24-2010, 07:58 AM   #9
ZoominC6's Avatar
Colleyville , Texas
I've seen those cast aluminum carriers on an Airstream and they're the best if you can lay your hands on one or two. Good luck.
Old 06-24-2010, 10:00 AM   #10
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
The most compatible parts at hardware stores are sewer and drain parts. Probably can get just a cap, 4" clean out cap for PVC-DWV..
Best Regards,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 06-27-2010, 01:17 PM   #11
Lakeway , Texas
Thanks so much everyone! This was very helpful.
Sewer Hose Storage Options 66Overlander Waste Systems, Tanks & Totes 2 07-21-2007 08:30 AM
How Much Sewer Hose To Carry? henw Waste Systems, Tanks & Totes 32 05-20-2007 07:16 AM
sewer hose john roeder Waste Systems, Tanks & Totes 5 04-23-2007 06:04 AM
Sewer Hose Recommendations? Neophyte Waste Systems, Tanks & Totes 4 09-05-2006 10:04 PM
Sewer hose mpumphrey04 Waste Systems, Tanks & Totes 2 11-30-2005 08:18 PM
