Old 08-01-2016, 03:12 PM   #15
2005 31' Classic
Gretna , Nebraska
I am about to work on my leaking black tank valve. I thank everyone who has contributed to this and other related threads.
I am about to cut an access panel so I can work on the valves and plumbing. How large a hole should I cut? Maybe there is not a finite answer other than "big enough" to get at things.
What about the supports/bolts between the dump valves? Should my replacement panel attach to a remaining part of this?
I see that a nipper is suggested as a good tool for the cut. Is there clearance for a small power saw with metal cutting blade? I will start investigating it all.
Thanks for your advice!
2005 31' Classic
16595 is offline   Reply With Quote
Replacing water tanks, holding tanks & battery? AussieGirl 1956 - 1959 Flying Cloud 57 10-19-2014 08:21 AM
Holding tanks gage is there a key or plugin to test the levels of the tanks. Buckshot 1999 Safari 1 08-18-2014 08:25 PM
How is the black tank held in place in a '64 Globetrotter? Globie64 Waste Systems, Tanks & Totes 1 04-16-2014 11:13 PM
how are the black and gray storage tanks held in place? gmwelder86 1974 - 1979 Sovereign 2 05-26-2010 11:28 AM
Where will the Mid-winter be held in '08 Minnie's Mate WBCCI Forum 13 08-20-2007 05:08 PM
