09-30-2013, 04:56 PM
1977 31' Sovereign
1976 31' Sovereign
Boonsboro
, Maryland
hose clamp connection leaking
OK,
just spent two weeks tearing out, repairing and am currently putting the bathroom back together in a 1977 Sovereign. Replaced the Thetford valve on the Blackwater tank and put it back in place- unfortunately without checking the integrity of the hose clamp connection between the valve and the tank. Realized it today and put water in to test- of course it leaks..
I already have the bumper back on, the floor down and the tub back in place- anyone have any pearls of wisdom??
09-30-2013, 06:07 PM
Biloxi
, Mississippi
Just a stab here, but I would say pull it apart and tighten the hose clamp.
MICHAEL
09-30-2013, 07:45 PM
1977 31' Sovereign
1976 31' Sovereign
Boonsboro
, Maryland
Thanks Michael,
I still have some access from above. I did tighten ot down a little further and will put another clamp next to the existing as soon as I get to the hardware store..
Greg
09-30-2013, 08:22 PM
2014 25' FB Flying Cloud
Palestine
Old boater experience: Suggest you loosen the hose clamp and ensure the hose is properly positioned. Next, add a second clamp with the adjustment screw 180 degrees around from the one on the first clamp. Probably belt and suspenders, but I don't like leaky connections, especially if they are difficult to access.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
10-01-2013, 05:54 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Second clamp only works if the hose barb on the valve is long enough for two hose clamps, which is not a foregone conclusion in an RV.
10-01-2013, 07:58 AM
1977 31' Sovereign
1976 31' Sovereign
Boonsboro
, Maryland
Thanks folks, will update you as to the status of the leak when I get the second clamp on...
Greg
10-01-2013, 12:10 PM
Wise Elder
2010 30' Classic
South of the river
Good luck with that.
The thin walled spiral reinforced hoses are prone to leakage. Sometimes a special clamp will help e.g.:
Spiral Hose Clamps
However even those are not a guarantee especially if the barb is not an exact fit.
You may need to try another type of hose.
10-03-2013, 07:11 PM
1977 31' Sovereign
1976 31' Sovereign
Boonsboro
, Maryland
So I got the second clamp on and am down to a very very small amount of leakage. Will probably have to do...
Thanks again to all who helped!
10-03-2013, 07:40 PM
Palestine
Sounds like Jammer may have the right idea. Barb size and hose size may not match. Is the barb metal or plastic? A deformed or damaged barb will almost always leak, no matter what Yoyo with the clamps.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
10-04-2013, 06:09 AM
1977 31' Sovereign
1976 31' Sovereign
Boonsboro
, Maryland
Just to clarify, this is where the LDPE (relatively soft plastic) black water tank clamps onto the Thetford valve mount which is a hard plastic and smooth. (no barbs). If it had barbs this would probably not have been a problem..
10-04-2013, 06:12 AM
1977 31' Sovereign
1976 31' Sovereign
Boonsboro
, Maryland
Oh, I forgot to add- the mount is new, the tank is old, but I did clean out the neck pretty dilligently before reassembly.
10-04-2013, 08:06 AM
1977 Argosy 24
Milltown
, Wisconsin
When I put mine together I smeared Vulkem all around the inside of the tank outlet, and outside of the valve fitting first. It has never leaked. I also used a heat gun on the tank outlet to soften it up before I tightened the clamp.
10-06-2013, 05:52 PM
1977 31' Sovereign
1976 31' Sovereign
Boonsboro
, Maryland
Thanks, sounds like you have a very tight (and likely permanent) connection!
10-07-2013, 06:29 AM
1977 Argosy 24
Milltown
, Wisconsin
Actually I had to take it apart about a month after I put it together, not because it was leaking. I just used the heat gun again on the tank neck, and it came apart very easily.
