Old 05-06-2004, 05:45 PM   #1
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Horrific Disaster Averted!
My wife has finally joined me down here in Florida at the campground. Well, she likes to use a lot of toilet paper. A few days ago, I came home from work, and she told me she thought the black tank was full. A peek inside the toilet bowl confirmed it was FULL. A trip to the rear of the trailer, and the black tank valve was opened. Nothing happened. I opened and closed the valve several times and still no dice. Great, I thought. I got out my handy tank washing wand and shoved it up waste pipe, while carefully holding the waste hose waiting for the avalanche. It never came. Nothing more than a few pieces of TP and some brown water, trickling out. I poked and prodded for an hour and made no progress. I really couldn't tell if the valve was broken or I had a blockage. The valve seemed to be open.
I gave up, and dumped a quart of RV digester bacteria stuff from Wally-World in and crossed my fingers. I let it set for 2 days, while we used the campground facilities. (A real pain at 4 AM).
Tonight, I decided to give it a go. The valve opened, the hose started shaking, and the tank emptied
So, if you think you may have a stuck or broken valve, or just a plain old blockage, try using some digester bacteria first, and let it set for a few days. It may just save you a huge repair bill, or worse yet a brown bath.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 05-06-2004, 05:55 PM   #2
jaco's Avatar
TMIrTP (too much info)regarding TP
Good tip Pick.
I will walk miles to avoid the dreaded "Brown Bath" even at 4:00 AM in a hail storm...
But I sure hope your "Much Better Half" doesn't read your posts or you may be in for alot of time over at the clubhouse at all hours.
jaco is offline   Reply With Quote
Old 05-06-2004, 06:27 PM   #3
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
I wish I could say thanks for sharing that with us but....
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 05-06-2004, 06:43 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
run her around the block a few times?
hey pick
might be worth your while to fill the tank 1/2 full and take the trailer out for a little spin and dump the tank again.
what does the mrs. think of the trailer life?
john
you call them ferrets, i call them weasels.
Old 05-06-2004, 07:33 PM   #5
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
John, she has only been down here since last weekend, but loves it so far. She has been couped up all winter in Ohio, so this is a welcome change.
We should be into our new house by next weekend, so we will be moving the A/S soon after that. (I'll be sure and dump in a few bags of ice for the trip home) There is a clean out for the septic system that I can use to dump the tank, that has easy access.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 05-06-2004, 07:34 PM   #6
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Originally Posted by Pick
...A trip to the rear of the trailer, and the black tank valve was opened. Nothing happened.
Horrors! The stuff nightmares are made of!
Glad to hear the digester did the trick!
Stephanie
Old 05-06-2004, 07:43 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
pick,
glad to hear you and mrs. pick are enjoying your new digs!
good luck on your move! hope it all goes well!
john
Old 05-06-2004, 10:55 PM   #8
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
You know...
Pick,
You sure have put a whole new meaning to the phrase,
"cocktail hours"...
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Veneer Disaster...can anyone help??? tin can luv Interior Restoration Forum 16 04-05-2004 07:54 PM
The ultimate disaster - Airstream rollover ipso_facto On The Road... 44 05-07-2003 12:01 AM
Disaster Weekend davidz71 Our Community 11 07-03-2002 04:27 PM
