Old 09-25-2007, 06:32 AM   #1
Denis4x4's Avatar
Durango , Colorado
Hooked hose to flush valve instead of city water...
....without opening tank valve. I was tired and not paying attention. Situation existed for at least 10 minutes before correcting the hook up. Lots of water leaking from pan and dripping on 1/4" copper tubing. This is a Safari FB and the carpet between the twin beds was damp.
I'm of the opinion that no permanent damage has occured and I've put a RED pvc plug in the flush valve to remind me never to do this again.
Any thoughts/opinions?
Denis4x4 is offline   Reply With Quote
Old 09-25-2007, 07:00 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I assume that you hooked a water supply hose to the sewer flush inlet and turned on the water. I recently had a similar episode. I had hooked up the sewer flush and drained the black tank. I closed the black tank valve, filled the tank with fresh water from the flush inlet for a rinse. I got side tracked with a phone call and forgot to open the black tank valve. SuEllyn walked in to notice water coming from around the bottom of the toilet. After a thorough clean up , everything seemed to be OK. Hopefully yours will be OK too.
We put signs on our inlets to try to avoud your mistake.
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 09-25-2007, 07:03 AM   #3
moosetags's Avatar
Sorry! Here is the photo that I intended to post.
Old 09-25-2007, 07:06 AM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I've always thought the two connections are dangerously close and poorly marked.
Old 09-25-2007, 07:39 AM   #5
Images: 59
and you should never put the "dirty" connection above the "clean" connection.
Thats Sanitation Safety 101.
Old 09-25-2007, 08:00 AM   #6
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
Besides "Ewwwww"? I like Moosetags plastic placards, hard to miss them.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 09-25-2007, 09:21 AM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
Not sure how long ago this happened but if it just hapened wet vacuum that rug as much as you can. Look under the bed and remove the plastic construction sheet to get to the rug under the bed.
The Flack Board that the floor is made with needs to be dried or it will go soft and it will not dry under the plastic.
If you filled the black water tank how did water get up to the rugs? I would look for a leak around the base of the toilet or the vent pipe. That system should be water tight.
2004 Excursion 4x4
Old 09-25-2007, 09:31 AM   #8
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Great placards Moosetags - I keep learning from the master - so, where did you have them made?
I do not have the flush connection over the city water connection but do want to label some things on my camper.
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 09-25-2007, 09:37 AM   #9
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
IF you got water oon the floor there is leak somewhere. Obviously.the toilet is not seated properly or one of the vent pipe conections is loose. If everything is tight the overflow should be running down the side of the trailer from the roof. Not a pretty sight but better than having it inside.
Michelle TAC MT-0
Sarah, Snowball
Old 09-25-2007, 09:50 AM   #10
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
Do you use a designated hose for the sewer flush? It's too bad there isn't a different kind of hose fitting, e.g. propane tanks have left handed threads except for the newer OPD external connections.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
1974 safari water leak when hooked to town water Jasper_pilot 1974 - 1979 Safari 8 06-09-2007 02:18 PM
No Fuss Flush and Fresh Water Hose? docbluedevil Waste Systems, Tanks & Totes 3 04-07-2004 10:07 AM
Filling H20 Tank via Hooked-up Hose Mike76251 Fresh Water Systems 9 03-20-2004 07:39 PM
City Water Valve Assmbly Question sladew Fresh Water Systems 3 08-11-2003 10:38 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
