Old 05-23-2002, 03:53 PM   #1
74Tradewind's Avatar
Question Holding Tank Wiring
Does anyone know how to test the contacts in my holding tanks?
My gauge reads 1/4 @ 5 gallons and 3/4 at full. Is this just an adjustment at the gauge? There is a screw head in the panel front to fiddle with the gauge. I do not have the wiring diagram or the repair manual.
I also just replaced the old thetford (no parts available) valves and installed valterra. And the new pergo floor I just installed looks great. Only took about four hours.
74Tradewind is offline   Reply With Quote
Old 05-23-2002, 04:22 PM   #2
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
The service manual with my '77 says to fill the tank all the way up, press the rocker switch to indicate level and then use a small, thin screwdrive through the hole provided in the control panel to move the needle to full. I'm not sure if this procedure works with yours but it seems feasible. I would want to know if the thing was working toward full more than empty. Also be aware that battery voltage/strength affects the settings. I have flushed my grey and black water tanks within the last several weeks and will be adding probe cleaner the middle of next month in preparation for a June 28-30 outing.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 07:52 AM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 11:13 AM
Holding tank warming TomW Repairing/Replacing Floor &/or Frame 5 01-07-2004 11:03 AM
Holding tank plumbing question yukionna 1997 - 2004 Bambi 15 09-10-2003 08:00 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
