Old 12-23-2006, 09:01 AM   #1
1976 26' Argosy 26
Jacksonville , Florida
Holding tank Valves
Hi again, Does anybody have any experience in replacing the grey and black holding tank valves? I believe they are called Thetford Valves. I have a 26 foot 1976 Argosy. My tanks are located in the back of the trailer as is the bathroom. My tanks are in good shape but the valves leak when closed. Any thoughts are appreciated.
Zadaschwartz
zadaschwartz is offline   Reply With Quote
Old 12-23-2006, 09:13 AM   #2
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
valve repair
hi zada- Repair kits, with new O-rings, gaskets, and such, are available from Thetford directly, if you want to go that route. Their phone number in Indiana is 219-294-6491. The re-build kit I bought for my '72 was only $7.69, part no. 09872. (This was for the black tank). Or you can just install a new valve assembly. Either way, you'll probably have to remove the tank, which involves getting the belly-pan out of the way. Good luck- tim
tphan is offline   Reply With Quote
Old 12-23-2006, 09:26 AM   #3
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Zadaschwartz
Yep. It's not too bad the hardest part is gaining access to them. Thetford is the brand name. I have found that dropping the back section of belly pan is the cleanest way to do it. If the pan has not been cut before, cut it side to side at a rivet point. Bolts in the bumper can be a bear you'll want to remove it. Drill out all pop-rivets and it will slide out. Some people will cut a access hole in the belly pan to do this job, but I like the belly pan section removal. The valves are straight forward in there repair or replacement. Take them apart and give them the once over, and if you are not happy with the scratches in the slide or housing, replace the valve don't rebuild. It's far more work to get back at the valves a second time.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 12-23-2006, 09:32 AM   #4
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I vote for the access hole, providing you've got a spare piece of aluminum to make a new cover with overlap (or you could make new gussets along the edges of the hole, then use the original piece).
Cutting the belly pan along a rivet line will make it difficult to re-secure. The rivets are in the frame cross members, about 1/8" steel that will not be the easiest thing to drill, plus the flange is not very wide, so a seam there is a problem if you don't have enough skin to make an overlap.
I don't know about your particular installation, but in the Caravel and Overlander the valves were accessible without having to do anything with the tanks.
Zep
Old 12-23-2006, 12:47 PM   #5
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Gate valve replacement
For what it's worth, here is another actual experience. I have a 76 31ft Sovereign International. Getting to to the valves is a bit troublesome, you have to cut an access hole right under where the valves are located. However the bigger problem is getting the valves off the holding tank and the 3" sewer pipes. The valves are fastened to the holding tanks with 4 big screws. If the screw heads are badly rusted, then they can be very difficult to remove. Further, in my case, the valves are glued to the 3" sewer pipes. They have to be cut off. That requires you to replace the old valves with new valves ($55.00 each). And.....you will also have to put in a new coupler to the sewer pipes or possibly replace an elbow, depending on how your sewer pipes are installed. In my case, I had to remove the rear bumper and remove the plastic hose caddy and cover just to get at the sewer pipes to complete the installation. It cannot be done any other way. I hope I never have to do this again.
My valve leak was caused by the gasket in the valve having a big chunk of rubber missing.
Good luck, Bill
lebolewis is offline   Reply With Quote
Old 12-23-2006, 03:04 PM   #6
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
This is another fine example of why some of us prefer our AS motorhomes. Not only is my black tank valve completely exposed but I can work under the bus without having to jack it up.
Once you have access you should be able to disassemble the valve for rebuilding. Take a good look at the connection push/pull rod for corrosion. Mine broke and required another rebuild of the complete valve.
As you put it all back together use a good amount of valve lubricant to help the slide.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 12-23-2006, 04:52 PM   #7
Van
1977 23' Safari
Hillsboro , Oregon
I've done both of mine too. As mentioned, the most difficult part is getting to them.
I bought the gasket replacement kits and took mine out, cleaned them up and replaces the gaskets. Reinstalled and worked like a charm.
Van
2009 F-350 FX4 Crewcab 4x4 6.4l
former '78 Argosy 20' Minuet owner
former '77 23' Safari owner
former 25' Fun Finder X-250BHS SOB owner
current 26' Komfort Trailblazer 262BSLE SOB owner
Van is offline   Reply With Quote
Old 12-23-2006, 07:21 PM   #8
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Did mine from the top if this helps?
You can see a hubless adapter where I had to make a cut to get the whole thing out.
'77 Sovereign Intl 31' CB
Old 02-23-2007, 08:25 AM   #9
Wrenches for repairing dump valves.
I recently overhauled the black tank dump valve on my side bath Excella. The valve had become steadily more difficult to open and shut over the years, and I knew I would eventually have to do the repair, and do it while living full-time in the trailer. Therefore, a year ago I cut the inspection hole in the belly pan, and fitted a hatch with 25 stainless roofing screw. A week before I planned to do the repair , I removed the access hatch, and noticed, as stated in the Airstream manual, that the 4 securing bolts on the pipe clamps securing the valves all point upwards. This is clearly to make it easier in the factory, as the floor is fitted after the dump valves are installed. Thank you, Airstream! The manual suggests a short open-ended wrench to loosen these. This is quite impossible, as the securing nuts are deep down between the valves and the tanks. I found that the necessary tools were a Standard Deep Socket set. The sizes required are 7/16 inch for the tank to valve bands, and 5/16 inch for the two bands on the rubber coupling. Mine were from Wal-Mart, a Stanley Standard Deep socket set, # 85-730, 6 pt, 3/8th drive, with a 6 inch ratchet and a 3 inch extension. I was just able to get this and my hand above the clamps and loosen them, after spraying the threads with WD40. I swivelled the clamps round so that the nuts were easily accessible, and then re-tightened them.
With this preparation I was able to complete the repair while my wife was out at the store one morning, without disrupting the use of the trailer.
The problem with the valve was that it was completely covered with a hard rock scale, presumably from using the water in Florida, a limestone area. Any ideas on preventing this? How about removing the scale without demolition? Hydrochloric acid on the pluming system would be a bit fierce, I suspect.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 02-25-2007, 09:14 PM   #10
1975 31' Sovereign
1977 23' Safari
Originally Posted by nickcrowhurst
...The problem with the valve was that it was completely covered with a hard rock scale, presumably from using the water in Florida, a limestone area. Any ideas on preventing this? How about removing the scale without demolition? Hydrochloric acid on the pluming system would be a bit fierce, I suspect.
Nick.
LimeAway, used for getting scale off of glass shower doors?
Zep
Old 02-26-2007, 01:09 PM   #11
Zep
Thanks, Zep, I'll see what chemical that is, and speak to Thetford.
Nick.
Old 03-02-2007, 07:09 AM   #12
LimeAway contains phosphoric acid as its active ingredient, according to the parent company website. Page F47 in my trailer's Airstream Manual lists the chemicals that will not harm the tanks and valves. Phosphoric acid is not listed, but a 10% solution of hydrochloric acid is listed. My elementary chemistry memories tell me this will dissolve limestone, producing carbon dioxide gas as a by-product. I'm hoping that will also help to clean the black tank indicators, which I suspect are partially covered in limescale.
Nick.
Old 07-16-2007, 08:36 PM   #13
JW84345's Avatar
1969 27' Overlander
, Michigan
How did you get to the valve?
... I don't know about your particular installation, but in the Caravel and Overlander the valves were accessible without having to do anything with the tanks.
Zep
How did you get to the valve on the '70 Caraval? Your Overlander? Are they rear bath models? I have a '69 Overlander. I have no desire or time to get into a big project like removing the black tank. Maybe in the fall, but I have another 4 day trip to a MI State park (no hook ups) planned in two weeks.
JW84345 is offline   Reply With Quote
Old 07-31-2007, 09:58 AM   #14
77airstream's Avatar
1977 31' Sovereign
Lakeland , Florida
Question Dump valves on center bath?
Are the dump valves on a center bath any different than on a rear bath? Where are they located? A slight problem I have is sometime in the past, my guess is, someone thought they needed to yank on the handles to free the valves, so the handles are no longer on the unit. Does anyone have any advice to give?
77airstream is offline   Reply With Quote
Can I use "regular" antifreeze in my holding tank? Luckydog Airstream Motorhome Forums 6 11-25-2002 07:01 AM
Holding tank valve pull's camphost Waste Systems, Tanks & Totes 3 10-31-2002 11:11 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
tradewind holding tank McGill Waste Systems, Tanks & Totes 3 06-22-2002 09:28 AM
Holding Tank Wiring 74Tradewind Waste Systems, Tanks & Totes 1 05-23-2002 04:22 PM
