Old 10-08-2002, 08:25 AM   #1
camphost's Avatar
Question Holding tank valve pull's
I need to know what I am going to find when I open the inspection cover for the holding tank valves? Both tanks pull arms are disconnected or broken. Will I need to replace the valves or will I be able to re-attach the pull arms to the valves? These are Thetford valves I assume.
camphost
camphost is offline   Reply With Quote
Old 10-09-2002, 05:34 AM   #2
1993 29' Excella
Jonesboro , Louisiana
Both the holding tank valves have a short stainless steel shaft with a small hole in the end. The handle extension slips over this shaft and is secured with a pop rivit or sometimes a cotter key. I'll bet the reason that it is broken off is that the valve has become very hard to operate and excessive force was applied breaking the rivit off. Before attaching the handle extension it would be a very good idea to check the valve itself to make sure it is operating smoothly. If not it would be a good time to install a repair kit. These kits are readily avalilabe from most RV parts places. Good Luck,
James Schmidt
29 ft Excello 1000
97 Expedition/Hensley Hitch/
McKesh mirrors
James Schmidt is offline   Reply With Quote
Old 10-09-2002, 06:19 AM   #3
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Read this for a little hope on your exploration of your dump valves. Nice thread with a lot of tips and a happy ending.
http://www.airforums.com/forum...&threadid=1965
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 11-01-2002, 12:11 AM   #4
Joan D'Andrea's Avatar
Send a message via Yahoo to Joan D'Andrea
As always the application of a blast of WD 40 every now and then will keep those valves nice and easy to move. I spray just about everything underneath with the stuf including the jacks. WD 40 seems to attract dirt so Keep a pair of gloves in the dump out hose box to save your hands and apply liberally in the future and everything will work like a charm. JLD
Kalakkala II
Joan D'Andrea is offline   Reply With Quote
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 08:52 AM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 12:13 PM
Holding tank warming TomW Repairing/Replacing Floor &/or Frame 5 01-07-2004 12:03 PM
pipe between black tank and dump valve gerbermania Waste Systems, Tanks & Totes 4 10-22-2003 09:21 PM
Holding tank plumbing question yukionna 1997 - 2004 Bambi 15 09-10-2003 09:00 PM
