Old 11-08-2004, 09:28 AM   #1
JerryG
seamusthegray's Avatar
2004 31' Classic
Louisville , Kentucky
Holding Tank Sensors
I have a 2004 Classic 31'. The auxillary holding tank shows full on the monitor inside the trailer. However, the tank has been emptied.
Apparently a sensor is stuck. Does anyone know where the tank sensor and sensor harness is located and how to get to it?
Anyone else had this problem?
Jerry Greenlee
Louisville, Ky
2004 Airstream Classic 31'
2004 Dodge Ram Quad 2500
seamusthegray is offline   Reply With Quote
Old 11-08-2004, 09:36 AM   #2
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Much has been discussed on this topic.
Try this:
http://www.airforums.com/forum...t=tank+sensors
or do a search "tank sensors"
The problem has yet to be resolved. Nut you are in good company!
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 11-08-2004, 09:46 AM   #3
JerryG
2004 31' Classic
Thumbs down Thanks!
Try this:
Jonathan
After I sent the message I did research in the forums and found I am not alone. I apologize for sending the message before doing the research.
Jerry Greenlee
Louisville, Ky
Old 11-08-2004, 09:52 AM   #4
Interestingly, I have never had problems with the holding tank sensors. And this in a soon-to-be 20 year old coach. But apparently this is not the norm with the older system either. I have yet to hear of a holding tank sensor system that is truly reliable.
Mark
Old 11-08-2004, 09:58 AM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Ironically, the older system which was suppose to have the problems, worked better than the "new" system in that started in '04. My tank reads various levels depending on outdoor temp, etc.
Old 11-08-2004, 12:44 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Mark
Interestingly enough I have always had problems with sensors on every TT I owned (including my Safari) until I got the new Classic. We passed through an entire season so far with everything staying correct. So for all intents this is my first time to see everything working correctly.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 11-08-2004, 03:01 PM   #7
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
They are pretty chancey
My 2003 black water tank reads constantly full even after the tank has been flushed. I don't care too much since on the 25 I can simply look down the opened toilet and see the level. The black tank is big enough that it has never come close to being full. I'll get the dealer to look to it when I'm there for something else.
The gray sensor is working fairly well as is the fresh water sensor.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 11-08-2004, 03:38 PM   #8
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I really enjoy posts about sensors acting up since I have none.
I check the black tank by shining a flashlight down the toilet while holding the foot pedal down. But I have to be quick since I don't turn the water valve off - the turbulence makes the level easier to judge.
I go outside and lift the portable gray water tank to judge its level since I do not have one built in to my '67 Airstream.
The lower sight glass fitting on my fresh water tank froze & broke around 1972.
But with the problems you guys have, I have yet to experience sensor envy!
Tom
Holding Tank sensors andyfuson Waste Systems, Tanks & Totes 43 01-09-2009 10:16 PM
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 07:52 AM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 11:13 AM
Holding tank warming TomW Repairing/Replacing Floor &/or Frame 5 01-07-2004 11:03 AM
Holding tank plumbing question yukionna 1997 - 2004 Bambi 15 09-10-2003 08:00 PM
