Old 02-04-2004, 04:47 PM   #1
Joe62984's Avatar
Holding Tank Probes
I am adding a gray water tank to a 1970 Overlander International. Is it possible to install level probes in this new tank and read the levels with the existing control panel. I thought I could use a three pole toggle to switch between tanks. Thanks
Joe62984 is offline   Reply With Quote
Old 02-04-2004, 07:27 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I'm sure it's possible. Just need to get the probe access point fabricated, mounted and connected.
Old 02-05-2004, 06:19 AM   #3
1988 34' Excella
1993 30' Excella
Hillsboro , Texas
Perhaps you have better luck with tank sensors than I do, but, considering how unreliable they seem to be, do you really want to expend that much effort for something that works so poorly?
linc54 is offline   Reply With Quote
Old 02-05-2004, 06:44 AM   #4
Aluminut
2004 25' Safari
. , Illinois
That's a good point. Either system could be installed. I would think the current system Airstream uses would also be easier to install compared to the old sensor types.
I will say however, that I had no problems at all with the older system that was placed in my '03. I suppose that could be due in part (besides luck) to me flushing the heck out of the tanks.
Eric
Old 02-05-2004, 08:09 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
you don't suppose it could be due to the fact that your "old" trailer was never (and still isn't) "old"???
