Old 10-19-2003, 08:39 PM   #1
1998 28' Excella
Pensacola , Florida
Smile Holding Tank Dumping
Just had a successful dump (my holding tanks)! I used my sewer clean out on the side of the house, next to the driveway where my 25' AS TT is parked. Beats hooking up and towing to nearest dump station. And its free! Any comments? Anyone else tried it?
jalewis is offline   Reply With Quote
Old 10-19-2003, 08:47 PM   #2
wallybyam's Avatar
No, don't know your address. However, if you invite me to stop by and give me directions, I will be happy to try it.
wallybyam is offline   Reply With Quote
Old 10-19-2003, 09:02 PM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
If your lawn suddenly gets really, really green right around that spot, you'll know we didn't aim so good.
"Between what matters and what seems to matter, how should the world we know judge wisely?" - E.C. Bentley, Trent's Last Case
drboyd is offline   Reply With Quote
Old 10-19-2003, 09:36 PM   #4
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Works for me
I can carefully thread my AS backward between the garage and workshop so that the outlet on the AS is just feet from the sewer cleanout. Beats using the blue canoe. I keep the shrubbery cut back to allow me to do this.
I also put the AS back there if want to do some work on it since the covenants say I shouldn't have it at home. In the summer, it is totally invisible there; in the winter, it can be partially seen from the road about a block away.
John W. Irwin
WBCCI #9632
Old 10-19-2003, 10:26 PM   #5
HOLDING TANK DUMPING
I use 10' lengths of 4" plastic pipes to convey sewer water a further distance. The pipes are just friction fit together, with an elbow at each end. The "down stream" end has a reducer to allow the pipe to fit into the stationary pipe. (I installed a stack with removable cap, into the top cover of my septic tank.) Easy set up, easy clean up, easy tear down / storage. Also great for courtesy parking.
ChromeHome is offline   Reply With Quote
Old 10-19-2003, 10:56 PM   #6
drboyd's Avatar
1978 25' Tradewind
I ordered a "Sewer Solution" from www.sewersolution.com. They have supposedly scratch and dent units cheaper than retail. Mine looked (and smelled ) brand new. Between that and a Valterra to Thetford adaptor, I can pump the poop thru a pipe over the plants and plop it in the sewer cleanout.
Perhaps.
I have the stuff, but I haven't physically tried it yet.
Old 10-19-2003, 11:06 PM   #7
1998 28' Excella
Pensacola , Florida
Talking
Thanks to all who replied. I forgot to add... no runs, no drips no errors! I also thought I had a problem with my level indicators, as I could never get the levels to indicate below 2/3 full on the black tank. The PO had not used the trailer and I was fearful that I had a buildup of hard "stuff"! Well, I did have a problem with build-up, At home, I have access to plenty of water w/ sufficient pressure ( I have a built -in black tank back flush) and am on sewage, so I had plenty of time to "work " the system. Now my level indicators read empty. I hope that change indicates that my black tank is truely empty.
Jim:
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 07:52 AM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 11:13 AM
Holding tank warming TomW Repairing/Replacing Floor &/or Frame 5 01-07-2004 11:03 AM
Holding tank plumbing question yukionna 1997 - 2004 Bambi 15 09-10-2003 08:00 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
